Massey 135/Perkins diesel alternator
   / Massey 135/Perkins diesel alternator #1
meporsche
Member
Northern Tier of PA
Hi,
My local NAPA just knocked me over with a price of $244 for a rebuilt DR 1100-336, 37Amp alternator. DOes anyone know what else can be swapped in there that will fit the mounting brackets?
Many thanks if anyone can offer some help.
Darwin
   / Massey 135/Perkins diesel alternator #2
I'd be way surprised if you couldn't cobble a delco 10SI or 12SI in there. That's what the bulk of old tractors use. 25$ at most junk yards.. or about 50$ from auto stores.
they are a 3 wire setup.. though can be had as 1-wire usually for a lil more money.
for 3 wire setup, there is a charge stud and 2 spade terminals.. marked 1 & 2.. #2 is sense and loops to the charge stud. #1 is hooked to the run side of the key switch.. IE, something that gets power whent he tractor is on. on a gas tractor you would use a 194 lamp inline with #1 so that it woul dnot backfeed the ignition whent he key was off.. a diesel won't have this problem.. however use of the 194 lamp is still good for 2 reasons.
1, it provides some resistance in line to the vreg so that if the charge wire comes off, the alt will not try to charge thru the#1 terminal.. also.. the lamp will act like a classic idiot light. IE.. lamp on with key on, and lamp off when charging starts ( usually about 400 rpm ).. you can get a trailer marker lamp and stick it right tot he dash and wire the lamp in it inline from ket to #1.
sounddguy
soundguy
   / Massey 135/Perkins diesel alternator #3
Give IAT a call and ask for Rich. I've purchased quite a few complete alternators and starters from them for our work equipment.
Not only do they have complete units in stock, but they also have just about all of the components. I have a bin full of slip rings, stators, regulators, brushes, etc. from them and regularly repair stuff as well.
I'll bet they'll not only have a new part in stock for your machine, (for lots less than a reman costs locally), but as an added bonus....since you're buying a new part they won't need your core back. Browse through their parts catalog and you'll probably be able to repair your old one, (whenever you have the time), for about $20.
They offer brand-new OEM stuff from Bosch, Valeo, Lucas, Magneti Marelli, etc., as well as the dirt-cheap imported knock-off stuff other vendors sell on eBay and such.
International Automotive Trading, Inc. (IAT)
If they don't have your model listed online, give 'em a call anyway. Their inventory updates more often than their website does.
   / Massey 135/Perkins diesel alternator #4
Hi,
Darwin
My 1964 MF-135 diesel originally had a generator. A previous owner replaced it with a Delco Remy 12-3 single wire alternator. Here are a few photos of that setup.
The top bracket has the number 3831195. It looks like an MF number, but I can't locate it in my MF135 parts manual.
Good luck.
   / Massey 135/Perkins diesel alternator #5
Hi,
Darwin
My aftermarket book is showing a listing for a 135 MF Perkins diesel for $98 + shipping. Ken Sweet
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
