logging tongs
   / logging tongs #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I need a set of logging tongs. Is northern hydraulics heavy duty ($70.00) tongs worth it?
   / logging tongs #2
You may not believe it but Tractor Supply sells the same tongs for $35. I got mine at Northern and a friend got his at TS a few months later.
The Northern Tool ones are not that heavy duty as I have broken the bolt and bent the heck out of them.
They are more skidding tongs that are not suited for lifting. Lifting tongs have the points angled upward rather than sticking straight out.
Another hint for the Northern ones. Take a grinder to the points and get them real sharp otherwise they tend to slip.
   / logging tongs #3
Chinese knock-offs at NT.
Get some that are better than theirs.
Bailey's is a good place to deal.
   / logging tongs
TSC carries the same logging tongs as northern hydraulics for less ? Good to know, I'll check them out, thanks.
   / logging tongs #5
As gwdixon alluded to- Any tongs you buy carefully look at the angle of the gripper points...a couple of years back I bought the small set that NT sells and they stink. Won't grip diddly because the angle of the points is wrong. Their bigger ones have much more angle back to the pull point, causing them to dig in better as one pulls.
I've been meaning to heat red hot and do some redneck blacksmithing on mine to get the angle better...:cool:
   / logging tongs #8
Searched Ebay for Logging Tongs - there are several sets out there. YMMV. Steve
Just bought one on eBay. Item # 200463533432 if anyone cares to look.
I don't think direct links to eBay are permitted.
   / logging tongs #9
I bought a pair from a local tool store and they have the prongs that are angled back in reverse position. Like someone said, the first thing I did was take a file to the prong points. That makes all the difference in the world when using them.
Craig
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
