Fuel oil and water
   / Fuel oil and water #1
FarmerGene
Member
Case D29
I got a little lax in my fueling procedure and a couple of gals of water contaminated diesel fuel got installed in the Case, Drained the tank, changed the fuel filter, bled all the lines twice. The tractor is now running fine, my question is....... Did the water in the fuel damage anything? Is there something I should add to the next tank of fuel as a additive, any other actions should be taken that I may of missed? Found the source of the water and corrected that problem.:thumbsup:
   / Fuel oil and water #2
What can get damaged from water in fuel is injector tips especially if the engine is warm. The water turns to steam and explodes the tips. If your engine is running fine you are in good shape. Companies make additives for removing water from Diesel but I am not sure who.
Roy
Roy
Thanks Roy, Have run out a tank & 1/2 of fuel seems to be running better then ever.:thumbsup:
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
2004 CATERPILLAR 262B SKID STEER (A51246)
2004 CATERPILLAR...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
