Stalling problems with a 2002 grasshopper 725g2
   / Stalling problems with a 2002 grasshopper 725g2 #1
2000silverz28
I just bought a 2002 grasshopper 725g2 zero turn mower. It has the 3cyn kubota gas engine(wg750-b).
It is hard to start sometimes but the main problem is its losing power and stalling. When you increase the throttle speed to fast it will stall. When you try to engage the blades it will stall unless you are choking it. When mowing it will sometimes loose power and then it spits out a cloud of black smoke and then its fine for alittle while.
The carb, fuel filter and spark plugs have been replaced. The valves were adjusted the other day and it seemed to help some. The repair guy said it may need the valves ground. He said to try running 93 octane gas in it and see if that would help. I haven't tried that yet.
Does anybody have any idea what could be the problem? I'm thinking about buying a service manual for the engine that I found online. Any help would be appreciated.
   / Stalling problems with a 2002 grasshopper 725g2 #2
From your description that adding choke help you could have a vacuum leak around the intake manifold. If you can access the area between the carb and intake ports spray carb cleaner around the mating surfaces. A change in engine speed will indicate that the cleaner is being pulled in through the leak.
Hope that helps and please let us know what you find.
I'm gonna try that this weekend. Do you know if this mower has any vacum lines? Anything else you would recommend?
Headache Rack (A50860)
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
UNUSED Artificial Grass Turf (A50860)
UNUSED Artificial...
1990 International 4900 Fire Truck (A50860)
1990 International...
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
