husqvarna 25 hp briggs 48'' cut hydro
   / husqvarna 25 hp briggs 48'' cut hydro #1
bass1
hello all,i am having a problem with a very good mower,there seems to be no throttle control at all,engine roars to avery high rpm. i have dissasembled the bottom part of the engine to view the govener.seems to be nothing wrong??i disassembled the carb and cleaned,again no visable problems:confused:any help would be greatly appreciated. 21 hp. sorry
   / husqvarna 25 hp briggs 48'' cut hydro #2
I feel for you. I have every problem under the Sun with my Husqvarna except what you have. My guess is you are getting air in the carb from somewhere causing it to lean out and Rage. Or maybe the needle and seat is stuck enought to dump a bunch of fuel in the carb to make it Rage., In any event, I think Husqvarna is a Glorified Murry. I could have bought a Cub for the same price and it will actually go backwards if you want it to.. Husky? Junk!! sorry...
   / husqvarna 25 hp briggs 48'' cut hydro #3
What do you mean by it will actually go backwards if you want it? Mine has no problem going backwards.
I would check your hoses, leaking gaskets and your carb. This **** ethanol crap wreaks havock on the carbs.
   / husqvarna 25 hp briggs 48'' cut hydro #4
Can you actually see the governor pushing on the throttle lever? Have you checked the main jet to see if it has vibrated out of the chamber, giving you a large amount of fuel. If that is the case, I doubt that it will idle. Is your throttle cable stuck in the max position.
Case Maxxum 140 (A50120)
Case Maxxum 140...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
