rod of choice for cast iron on AC?
   / rod of choice for cast iron on AC? #11
AC Nickel is a tough weld but there is hope. There is a Synthetic Nickel rod called Nickel Free that is made by a company called MG. When it works it is the Best Cast rod. When it doesn't, Its the worst but it runs good on AC or DC and costs 1/2 of NI55.65,94 or 99..Other than that yop will have to pay to get it repaired. Good luck...
   / rod of choice for cast iron on AC? #12
Preheat and NI rod I has worked well for me. I also have heard that the best steel rod is a 7018AC. Preheat weld peen and then slow cool is supposed to produce a stronger weld than NI rod. I have not tried it personally though.
   / rod of choice for cast iron on AC? #13
7018, 6013,9010,7024, all the Mild Steel rods are not a good choice for cast. That is why there is NI Rod. Otherwise everyone would Mig Weld it. You can Mig Weld it with NI Wire.,Works Awesome at $30.00# on a 33# spool. Brazing Rod will work better than the above mentioned Stick Rods. Or a NI Silver mix like Harris 14FC. Remember PL400 or Liquid Nails will even work if there is no stress or heat involved.:D
I have some 7018ac.. will try it on my next project.
soundguy
   / rod of choice for cast iron on AC? #16
It has been a long time since I welded Cast iron. the pre heat and post slow cool is right. I remember there are two kinds of rod. One is machinable and the other you can make multiple passes. I think . It was a looong time ago. There is probably newer rod now.
I still have some of that multiple pass rod.
   / rod of choice for cast iron on AC? #19
ni-rod is a nice generic term and it works well on cast iron. I use stainless steel rod in 309/316. This is a high nickel rod. It just works wonders on all steels and cast iron. Use it only with AC.
I built two trailers, a pipe rack, shortened a pitman arm on my truck and modified some structural building steel framing with 309/316 and have bever seen any stress cracks. My favorite rod.
I recently welded some mild steel angle iron onto a farm disk that was very hard and crystaline. It would not accept 6011 or 7018 without cracking, but the 309 worked perfectly. I also broke off my drill press table that was cast iron and welded it back together wth the 309. Excellent. Long ago I used it to weld bailer needles back together. No preheating with any of these.
But an engine block is a different story. Heating probably won't help because they have such a complicated internal shape and are so thin and thick. I couldn't make it work. Also, any distorsion that results might be bad for alignment.
   / rod of choice for cast iron on AC? #20
MORE good info! I'll have to look into that rod, had not heard of it before.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
14ft. Deer Gate (A53424)
14ft. Deer Gate...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
