I have a problem with my 6400 transmission with a syncro transmission.
When you put it in gear it will not move unless the rpms are up around 1800.
The system pressure is 170 at startup but then drops to around 100 within a second or two and the low pressure light comes on.
I have replace the transmission pump, pump housing and all the valves in the house. Also replaced the main pump and charge pump for the hydrualics.
Any ideas about why it is dumping the system pressure?
