PTO shaft safety plastic tube source
   / PTO shaft safety plastic tube source #1
moeh1
Gold Member
Upstate NY
B2150DT / B2150 Hydro / Hinomoto JF-1
I bought a used implement, the PTO shaft must have rubbed on something because the plastic tube is abraded completely thru. I have it taken apart, hoping I can just buy a new tube and put it back together, but not finding lots of Bondioli and Pavesi parts after a brief search. Any sources out there? I see ASC has tubes for the Eurocardan -either the 1-2-3-4 series or the 5-6-7-8 series, if anyone had one and could check the diameter, that might be a viable option. The outer shell is the one I need, it is about 2-7/16 ID, the OD is just over 2-5/8. Hoping I'm not the first person to have this problem?
Thanks for any help!
   / PTO shaft safety plastic tube source #2
check with a tractor supply store if there is one close by. they carry some of those. also check with your local tractor dealer.
Thanks,
I'll check the local TSC, didn't see anything online. The dealer is hard for me to catch open with my work schedule.
   / PTO shaft safety plastic tube source #4
Check with manufacturer if you can, I bet they'd be more than happy to send you one. They are usually huge proponents of you being safe when using their equipment.
Wouldn't be surprised if they did not charge you.
Joel
   / PTO shaft safety plastic tube source #5
G'day check out the bare co site their lever release system is great for greasing and they they come in two different sizes to suit all the different shafts out there
Jon
   / PTO shaft safety plastic tube source #6
ditto that.. my local tsc store has a few different plastic shields in stock.
soundguy
   / PTO shaft safety plastic tube source #7
My L4400 did not have a PTO cover supplied. I wanted to reduce the amount of dirt on the grease and make it safer so I simply cut a piece of irrigation pipe of suitable size and attached a length of wire to tie it to the tractor. Cheap, simple & effective.
Weedpharma
   / PTO shaft safety plastic tube source #8
We have the shields complete for both sided for $35.
   / PTO shaft safety plastic tube source #9
wow, good price too!
soundguy
CCI, that is a good price for the whole assy! Come to think of it, I got a seat from you awhile ago at a good price too. I'm hoping to find time to track down just the outer tube sleeve itself, if I can't I'll hook up with you.
Not having one installed just isn't safe enough for me.
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
