opiniones wanted on trailer jack
   / opiniones wanted on trailer jack #11
Get a bottle jack and blocks of wood. Look for the lowest point on the trailer and then subtract the height of the tire (to simulate it being flat). That's the compressed height of the jack you will need.
Oh, get a folding shovel too... never know.
Thanks for the ideas guys.
Here's where I'm at. I'll try to address all replies.
I picked up a 12 ton bottle jack and did a dry test on the trailer, with the assorted 2x6 and 4x4 cribbing I have, it worked fine.
My hi lift jack also worked fine.
I DO have the room to carry both, so will. I also picked up another 'spare' 14' chain. Plus a 3 ton comealong ( I love those.. just in case.. ). I already have a 4 ton electric winch. I carry a spare universal interstate battery with me on trips.. has side post and top posts.. will fit alot of trucks and tractors. My 'new to me' truck has plenty of toolbox space.. has 3 nice aluminum tool boxes in the bed.. one in the back near the 50g fuel tank in the bed, and 2 along the sides.
Got an assortment of hand tools.. usual stuff.. ratchets, pliers.. etc.. extra wire, terminal ends, and some spare marker lamps and such. both jacks fit fine.. picked up a couple extra ratchet straps now thaI have more deck length, plus a chain binder for my chain box. Picked up a dedicated 4 way lug wrench for the truck so i don't have to rob the one from the shop all the time now. I also carry a 15g air tank when tractor tripping.
welded up a step for my bumper reciever that is not used on that truck to make it easier to get into the bed.
I absolutely LOVE my 'the goose' gooseneck adapter that fits on 5th wheel rails. hasn't too expensive, has a lifetime warranty, and just like a 5th wheel adapter.. pull 4 pins and it comes out. has a free rotating ball that is replaceable by removing split rings and washers on the underside.
best of all.. that gooseneck pulls like a dream going down the road.. I already love it way better than my bumper pull. prodigy controlerl had no problems with it either. Finally got to road test the 4.88 rear end onthe interstate... to to about 73 she's about 2800 rpm. tached up pretty good.. but not too bad... keeps the exhaust temp up but the throttle is nice and responsive :) Yep.. I think I'm gonna like that truck and trailer together.
soundguy
almost forgot.
got the military folding shovel.. HAVE used it before !
soundguy
   / opiniones wanted on trailer jack #14
With a single axle trailer, in addition to the bottle jack, I carry one of those plastic ramp deals that lifts one axle while you drive/back on with the other. Real quick when your empty. With the dually, I just rely on the bottle jack.
FWIW, I never jack on the axle tube. Always heard that was a bad practice.
   / opiniones wanted on trailer jack #15
Not that it matters but I always jack tandem trailers by placing the bottle jack under the equalizer. Works great.
Chris
That's where I tested it.. it's a nice boxy piece.. easy to get to as well.
soundguy
   / opiniones wanted on trailer jack #17
Chris
I don't have a lot of experience with big equipment trailers but my tandom axel horse trailer does not need a jack. Just use some chunks of 2 X 8. One about 3' then 2' and 1'. pull or back the trailer so the good wheel is on the wood and your done.
   / opiniones wanted on trailer jack #18
That works but if the trailer is loaded near max you can damage the good tire or spindle from being overloaded.
Chris
I had a buddy that crushed one of those composite ramps that you pull up on to change a tire! that ended my thoughts of getting one.
besides.. I think the combo of a bottle jack and my hi lift jack will be good.
I've needed that bottle jack for a while. as rickb points out.. I was likely going to get hurt one day using that hi lift for everything.
soundguy
   / opiniones wanted on trailer jack #20
I had a buddy bust his jaw with one.... but thats a story for a different time....
2010 POLARIS RANGER 4X4 4 SEATER UTV (A52576)
2010 POLARIS...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
