New 140 Owner
   / New 140 Owner #1
oldsudbury
Dear All:
I am the proud new owner of a 1961 Farmall 140, with turfs all around and an aftermarket 3 pt hitch. 2 pto's. Learning alot these last couple of days, but boy, do I love it. I need access to an owners manual, service manual, is there an online source or should I buy one? Looking forward to learning.
   / New 140 Owner #2
Welcome to the forum! I moved your post into the Farmall Vintage section so more of our members will see it and be able to help you out.
   / New 140 Owner #3
Dear All:
You should buy a service manual....by 2 pto's do you mean the standard pto and a belt pulley? .....the '61 123 cu. in. engine is virtually identical to all the rest of the 123s found in Super Cs, 230s, 240s, etc. slight changes in the intake manifold. Near bullet proof engines if you maintain it. Engine holds 5 qts of oil with a filter...change it. I would suggest you change the trans/rear end gear oil (80W-90) as well. The "drop down" rear wheel gears has its own gear oil resevoir..you will note by the "plug" on each side. Ask away, there are many 140, 130, 100, SA owners out here. BobG in VA
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
2024 Kubota RTV520D-AS (Dothan, AL) (A50123)
2024 Kubota...
2011 Ford Crown...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2017 Trail King TK14U 20ft T/A Flatbed Equipment Trailer (A51692)
2017 Trail King...
