My Tractor came to a sudden stop....
   / My Tractor came to a sudden stop.... #11
The seat switch will kill the motor but it won't click when you try to restart it. You would have an open circuit. I would clean the battery 1st. I would then try the seat.
I found the problem and I'm back up and running. After rechecking the battery cables again and the hydro pedal switch I decided to jump the seat switch. I disconnected the connector right under the seat and while attemping to get a wire inserted I noticed that the other end of the wire had come undone. Plugged both ends back in and she fired right up.:) Thanks for everybodys help!
   / My Tractor came to a sudden stop.... #13
So, the question is, "What was that clicking?" Not the solenoid ...
larry
   / My Tractor came to a sudden stop.... #14
probably one of the other relays
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
5004 (A55851)
5004 (A55851)
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
