Moving Heavy Rocks
   / Moving Heavy Rocks #11
I've never tried to move a rock that big, but I have tinkered around with tree stumps. The weight can get very high, very fast.
I like Mr. Jmarotz' approach...get just a little bit of lift on the thing, then drag it. I don't think a "clean drag" without giving it some uplift force will work too well.
If you spend more than 2 hours trying to move one of the rocks, I think your time is better spent splitting them. I've spent many an hour riding a rental jackhammer with a simple point inserted. Based on the rocks I've busted apart, you could probably split each of them into 4 pieces inside an hour. It's easier than you think and the jackhammer rents for around $100 for the weekend.
   / Moving Heavy Rocks #14
Found one site that indicated "granite solid" wt. 168# per cu.ft.
3 ' x 2' x 2.5' = 15 cu. ft. x 168 # == 2520 #
   / Moving Heavy Rocks #15
That's probably the meanest thing I've ever read on TBN.
Hey, even though I have heavier equipment including a skid steer and a mini ex, I have plenty of rocks here that I know the best I can do is help them slide downhill....and then there are those I can't even get loose.
Wasn't it Clint Eastwood who said "A man has to know his limits"?
OTOH, if the OP has a teen daughter and a bunch of boys that want to impress her..... :laughing:
Ken
   / Moving Heavy Rocks #16
I have moved many rocks that weighed to much for the loader by using using the 3 point
Using the 3 point to lift and drag the rock can flip the tractor over backwards. The ROPS would stop it from fully flipping but that rock would end up where your back, neck and head should be. I would not try it.
   / Moving Heavy Rocks #17
How about: Masonry drill, dynamite, fuse, match, run fast.
Dynamite requires permits and is not needed.
I dealt with two white granite rocks larger than these in the path of a 30" deep electrical conduit last week. The smaller of the two rocks was about 4'x4'x2.5'. A single 1/2" hole was drilled 10" into the rock. A 3/8th inch diameter by 4" long tube containing a small electronically ignited charge of black powder was inserted into the hole and then the top couple of inches were sealed with epoxy. After the epoxy dried the charge was fired from 200' away behind a hill. The rock split into 4 pieces and was removed from the trench. The small charge cracked but did not explode the rock. This was done on private land, not for commercial gain, without manufacturing any explosive or using any controlled substance. I do not recommend anyone repeat my process.
   / Moving Heavy Rocks #18
"OTOH, if the OP has a teen daughter and a bunch of boys that want to impress her..... "
So that is what the old farmer I worked for in high school was doing......... when hay had to be loaded three cute girls showed up, and as soon as it was on the trucks headed for the barn they disappeared.......... poof! All the wagons, and trucks had at least two more tiers than they would have without the girls I'm sure. :)
   / Moving Heavy Rocks #19
Well there is a time and place for everything.
Get the rocks out of the ground so you can move them.
Make sure you've a clear path to their destination,
Come next winter, water a path so you have an "ice road"
Trailmobile Van Trailer (A56438)
Trailmobile Van...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Bobcat S740 (A57148)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
