Hiding Zerk
   / Hiding Zerk #1
Mark Page
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
I'm pretty consciencious when it come to keeping my machine greased. Last fall I was greasing the zerk on the rock shaft's right side. It occurred to me that there should be one on the left side as well. Moved a couple of hydraulic hoses and there it was. It hadn't been lubed in the eight years since it was new. It's a pain to get the hoses out of the way so you can get to it.
I finally managed to get a gun on it and proceeded to pump the handle about 12 times without any excess grease squeezing out.
Have I done any damage? The 3pt hitch works just fine.
   / Hiding Zerk #2
Maybe a little excess wear, but I wouldn't worry about it, if it was me.
   / Hiding Zerk #3
if it ain"t falling off, or making a heck of a sqealing noise, it should be ok ;)
   / Hiding Zerk #4
You might think about running a grease tube to that location to bring the zerk out to a more accessible location.
   / Hiding Zerk #6
Where does one get grease tubes? I have a PITA zerk I'd like to make accessible.
Almost any place that makes hydraulic hoses can make what you need.
If you don't need a particularly long one you can also get the flex hose replacement for your grease gun, make one from that. You will have to fab up a bracket to mount the zerk end. KennyV
   / Hiding Zerk
Why can't I fill it. I've pumped a ton of grease into it. Is it squeezing the excess into the hydraulic system?
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
377789 (A51573)
377789 (A51573)
23013 (A53421)
23013 (A53421)
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
