Replace those Turnbuckles
   / Replace those Turnbuckles #11
Our tractor already has #40, or something close enough to work and I think most with interior turn buckles would.
For a number of applications, yes, the kit might be less costly. I have ALL the fasteners I could ever need to install the links and would use what I have.
If I could save 50% on everything we bought, but need to use what we have to fill in some minor gaps here and there, we could live like king and queen!
   / Replace those Turnbuckles #12
It is quite a bit different than the way it was on my turnbuckles, but not to say yours are the same or that you can't make it work. Worst case, you get them later if you can't make your parts work like you want. At any rate, the telescopic system is a lot better. I like the way they hold the lower arms apart and can line up easier with the implement. As I use the Pats system too, just back up, raise the lower arms up and get off and hook up the top link and your off. Good luck.
   / Replace those Turnbuckles #13
So for the 7800 you can order the 3030 versions and it fits? For those with a B7800 who did this can they confirm? Just wanna make sure before I start ordering.
   / Replace those Turnbuckles #14
The part #is L8430 3 point hitch stabilization kit. It sells for $169.00. This is standard equipment on the L4400 but optional on 2800 & 3400...
:thumbsup::thumbsup::thumbsup: Thanks...
   / Replace those Turnbuckles #15
Taiser,
Yes, the ones for the Telescopic stabilizers for the B3030 will work on the B7800. Check out the first response this thread from Bota7800. He & I both ordered ours as a kit from Tractorsmart. But due to duties, you may be better off to go to one of your Canadian dealers and order the parts unless you got a buddy in MI that wants to visit you. It is a pretty simple process to change it out. Getting the rod that they connect to was the toughest for me. I loosened the set screw, but there it still didn't want to come out too easily but could just get to it enough to tap it and get it started.
   / Replace those Turnbuckles #16
HI I HAVE THE SLIP STYLE AND HATE THEM ... I'LL BUY THOSE TURNBUCKLES IF THEY WILL FIT MY MAHINDRA 4500..
I WOULD HAVE SWAPPED THEM UP FOR YOU IF I HAD JUST GOT ON THIS POST A LITTE EARLILER..
THE SLID TYPE GET GRIT AND GUNK IN THEM AND WON'T SLIDE.. HAVE TO BEAT THE THING OFF .. BENDS THE ENDS SOME AND THEN THEY WON'T SLIDE BACK AND FORTH PROPERLY..
THEN THEY ALWAYS SEEM TO BE WRONG... HAVE TO SHIFT TO ONE SIDE
OR THE OTHER AND CAN'T DO IT WITH THE EQPT. ATTACHED.. TOO MUCH
PRESSURE TO PULL THE PIN OUT.. PAIN THE ROYAL ?#%&...
JUST TO LET YOU KNOW.. I LIKE THE TURNBUCKLES BETTER..
BOBO..
   / Replace those Turnbuckles #17
The stabilizer kit will fit the B7800 but it will also fit the B7510/B7610 tractors as well. (This is for sure.)
Edit: May be even the newer B2x20 machines. (This is a guess.)
   / Replace those Turnbuckles #18
L8430....where is the best place to buy this part? Anybody using today that has an opinion on the functionality???
Jim Shaw - KY
Kubota L3400
NH T5050
Polaris Ranger 700
   / Replace those Turnbuckles #19
I bought it, put it on... didn't like the play and slop, so I took them off and put them on the shelf.
   / Replace those Turnbuckles #20
According to the tractor smart website the factory top link for my B series is $152,,,,,,,,, OMG,,,,,,I put hydraulic TnT on mine and the hyd top link was almost the same price,,,,,,lmao
2020 FRYFOGLE 40 LOG TRAILER (A59575)
2020 FRYFOGLE 40...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
