Smallest tractor with grapple
   / Smallest tractor with grapple #1
kuboman
Canada
B3200, L5740,
Does anyone know the smallest available tractor from Kubota that has a Kubota grapple available for the loader? I have not had any luck finding a Kubota grapple.:confused:
   / Smallest tractor with grapple #2
That is because Kubota does not make grapples, they are all aftermarket.
Ok then does anyone know which models have a front hydraulic outlet and valve.:confused:
   / Smallest tractor with grapple #4
Kubota sells kits to add remotes front or rear for most models. Or you can build your own.
   / Smallest tractor with grapple #5
Exactly. Most poeple on TBN add the front remotes themselves from aquired parts or "kits" from thier dealer or companies like WR Long.
Search for these terms in the Hydraulics and Attachment forums for HOURS of reading:
grapple
remote
4n1
WR Long
diverter
3rd function
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
