1.5 vs. 2" rod on log splitter
   / 1.5 vs. 2" rod on log splitter #1
JimS
I found what I thought was a good deal on a 4" x 24" cylinder for a log splitter. But the rod is 1.5" Have heard of a few problems bending the rod but not sure how likely this is to be a problem. Should I be worried about this and go for 2"? Planned to run this at 2250 PSI from tractor hydraulics.
   / 1.5 vs. 2" rod on log splitter #2
Jim,
this will depend on how well the ram is guided and how the cylinder is mounted. If there are very minimal bending moments induced by the design you should be fine.
Note: For NFPA cylinders The "standard rod size is 1 3/4" on 4" bore.
Roy
   / 1.5 vs. 2" rod on log splitter #3
Hi! 2 in. rod is a lot more stong and more fast for return. But I think 1.5 rod cylinder dont bend if work in line with logsplitter knife. Good luck! Oldmech
   / 1.5 vs. 2" rod on log splitter #4
Jim,
It will work but less column strenght to resist bending, 2" will not give you any more power to split but will increase your speed on return stroke, the only benefit to 1.5" rod would be if you were pulling under load for more power (which you are not)....
Speed vs Cash are the trade-offs:confused2:
   / 1.5 vs. 2" rod on log splitter #5
JimS, I've been asking myself this exact same question without getting anywhere either. You'd think with a proper setup there would be no way to bend the rod but all the commercial ones are 2". Even Harbor Freight.
wdchyd, why does the 2" increase the speed of the return stroke over the 1.5"? Does it increase the speed of the push stroke too then?
   / 1.5 vs. 2" rod on log splitter #6
the speed is based on how long it takes the fluid to build up behind each side of the piston. for the split stroke, it's the area of the piston, which is pi*r^2, or 3.14 * 2^2 = 12.56 sq in. the the return stroke, you have the same area, but the fluid does not build up where the rod is. for a 2" rod, you have the area of the piston minus the area of the rod, or 12.56 - (3.14*1^2) = 9.42 sq in. since the return side has a smaller overall area, the fluid fills faster, making the time to return faster than the time to split. the larger the rod, the less area on the return side.
   / 1.5 vs. 2" rod on log splitter #7
Arrabil,
basically the 2" rod takes up more displacement in the front end than the 1.5", the amount of oil on the return stroke side of the cyl is less in the 2" thus retracts faster...
No, it does not change the speed of the push stroke (4" bore is 4" bore)
I'm sure KennyD, Aakkman, JJ and others can share the math with you:drink:(hint-hint)
   / 1.5 vs. 2" rod on log splitter #8
Lostcause,
you're a much faster typer than I, guess I'll have to learn to use more than 1 finger :laughing::laughing: Thanx for the numbers (can't count any more than 21) :laughing:(well maybe 20 1/2)
   / 1.5 vs. 2" rod on log splitter #9
Ah, makes sense. Thank you both.
I guess that makes the 2" rod worth the extra cost since its stronger AND faster.
   / 1.5 vs. 2" rod on log splitter #10
yup, faster on the return stroke. just remember that if you are using it in a fashion where you need the cylinder's force on the return stroke, then the larger rod gives you less power. you have to make a decision between power & strength then.
2019 CATERPILLAR 938M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2015 CATERPILLAR 257D SKID STEER (A60429)
2015 CATERPILLAR...
