Bale spears, 1 or 2?
   / Bale spears, 1 or 2? #1
dmay
Gold Member
Winnipeg, MB
2010 JD2320
I'm looking at buying a FEL/3pt bale spear. What do you think is the best all around choice for number of bale spears when moving 800-1000 lb round bales:
1) One spear w. two small stabilizers
2) Two spears
Has anyone found the two spear to also work well (enough) as a pallet mover?
Darrell
   / Bale spears, 1 or 2? #2
I've always had much better luck with 1 long center spear with two stabilizer prongs, than the ones with 2 spikes.
As far as a pallet mover... I don't think it would work very well.
   / Bale spears, 1 or 2? #3
We use a similar 2 prong setup made by Buhler on our 285 MF and, and in a pinch, we have used them as pallet forks, however, the spacing on the 2 forks are not adjustable and will not fit all pallets. Ken Sweet
   / Bale spears, 1 or 2? #4
For my money, it's the single long spear with stabilizers, hands down. Two long spears must be perfectly parallel not to bind either entering or leaving the bale. It's quite annoying to be stacking bales and having to fight every bale off the spear(s).
Bale spears make better pallet forks than none at all, but not by much.
   / Bale spears, 1 or 2? #5
I couldn't have said it any better. I agree.
   / Bale spears, 1 or 2? #6
For a counterpoint, with two spears a round bale will not spin. A single spear in a loose bale will sometimes not provide enough support and the bale will sag and the short stabilizers will not provide enough grip and the bale will spin. These problems go away with two spears. I use the Washburn spears.
   / Bale spears, 1 or 2? #7
Yes... if there is only a single spear and not two stabilizer bars or points about 16 inches long on both the left and right side of the bale stabber. But how often do you see a bale stabber with a single point and no stabilizers anymore...?
   / Bale spears, 1 or 2? #8
If anyone out there still uses the older New Holland chain rollers (850-851-853 etc.) or any baler that leaves a soft center core, then you definitly would use the 2 prong. Tight centered bales, use the 1 prong. Ken Sweet
   / Bale spears, 1 or 2? #9
Around here, the single spear is for round bales; the 2 spear deal is for large square bales (the 3x3 or 3x4 by 8 foot big rectangular bales).
Of course anything gets used is a pinch.....
--->Paul
   / Bale spears, 1 or 2? #10
Have used both types. Both do the job with hay bales. The two spear has the added advantage of being able to move some pallets and, when necessary, to hold stacks of logs or lumber.
That's my $.02 worth.
1996 Craftsman 17in Tiller (A47484)
1996 Craftsman...
2025 KJ K1912 UNUSED Livestock Metal Shed (A47484)
2025 KJ K1912...
More info coming soon! (A44572)
More info coming...
Utility Trailer (A45336)
Utility Trailer...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A44572)
2023 Ford F-150...
2017 Ford F-550 Reading Service Truck (A44571)
2017 Ford F-550...
