Practice Removing Your FEL
   / Practice Removing Your FEL #11
Two minutes during your first time?
Like I wrote...it's not a race...
Sure...why not? Maybe lots of time on other equipment led to the two-minute drill.
Now, do it in the dark, on a gravel surface, with mosquitos buzzing and someone yelling at you. :)
   / Practice Removing Your FEL #12
Maybe this should be in the 'embarrassing things I have done' section. :ashamed:
The first time I took of my front end loader, FEL, I did not release the hydraulic pressure in the line. I was able to get it off without knowing there was a problem. However, when I tried to hook the hydraulic lines the pressure prevented me from being able to fully insert the connector. I ended up with some paper towels, a plastic faced hammer, and a couple hits to vent some of the oil. It only took a tablespoon or two and I was good to go.
Now I always remember to put the bucket in float and move the control side to side to eliminate all the pressure. I have not had a problem since. :D
John
   / Practice Removing Your FEL #13
I wanted to take my loader off last year. No directions but it was very straight forward until I got to the hydraulic quick connects. They must be some cheap brand because the locking ring was rusted closed. I couldn't get them loose. So until I feel the need to get new connectors and replace the old ones the loader stays on.
   / Practice Removing Your FEL #14
OK, I read the instructions, then the timer started, but yes, just put the bucket near the ground, put in the stand, pull the two pins, tweak each set of cylinders a time or two and it pops off. Literally 2 mintues.
Montyhp
   / Practice Removing Your FEL #15
Yep, the weight of the FEL can contribute to that unsteady feeling when mowing. At minimum, I drop the bucket off. That's pretty quick (pull two lynch pins, then use the dump circuit as you lower the FEL arms).
Does it really make that much of a difference? I spent all day brush hogging yesterday with my bucket on. Other than watching my turns I didn't have any issues.
Now you guys have me wondering what it would feel like to hog without the bucket. I guess I am finally going to have to learn how to take it off.:ashamed:
   / Practice Removing Your FEL #16
Probably going to depend on the size of your tractor. I really can't tell a noticeable difference with my Case, so it stays on; hasn't been off in years. I sure won't hurt to try.
   / Practice Removing Your FEL #17
How much of a dfference will depend upon your property (sloped, level, etc.).
Level? Probably not much of a difference except dropping the bucket takes some of the load off your front axle.
Sloped? You might feel a pretty dramatic difference. I did...
   / Practice Removing Your FEL #18
Montyhp
The whole point of "it's not a race" is to ensure (or help ensure) removing and re-installing tthe loader is done safely.
Some guys are more mechanically inclined then others and will pick it up pretty quickly. Others, not so quickly. I'd guess quite a few residential TBNers never operated a wrench...then they bought a tractor. Those gents and ladies are the folks I'm writing to...
First time I dropped the loader, I'd guess it took about 15-20 minutes. I'm mechanically inclined, but I'm one of those methodical guys who takes his time. You know....read a step, perform the step....read a step, perform the step...
Now, after dozens of removals and re-installations, I'm quicker. My only issue now is a bad hand (result of a stroke) that just isn't strong enough to work those QD fittings quickly. Dropping the loader (including on and off the tractor) takes 3-5 minutes (estimated...never timed it). For me, installing takes longer...mostly due to that bad hand. Sucks...but a bad hand is better then being dead, right?
   / Practice Removing Your FEL #19
I can sure identify with that as I have little use of my left hand/side and my wife helps me with a lot of this stuff as I get older. Funny how she can do the QD, but air chucks mystify her and I have to do them.:)
   / Practice Removing Your FEL #20
The only time I mow with the FEL on is in real steep conditions where I actually want weight on the nose........ that is maybe 5% of the time and my farm has very few flat places.
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
