Deere Plow - Oldie but Goodie?
   / Deere Plow - Oldie but Goodie? #1
butternut
Member
Addison County Vermont
New Holland T2320
I have an opportunity to buy this John Deere model "25" single bottom plow for $500. It is in the JD parts catalog (online), however my local dealer has verified the parts are no longer orderable, at least from that source. If I were to replace anything, it'd be aftermarket stuff I guess. They made a phone call and determined the 25 was made for Deere by a company in Kansas. The year is about 1984 I'm told.
The coulter wheel, which is in decent shape, is removed because the mounting bracket has a small crack, and the owner is getting a buddy to weld it. Seems like a pretty tough/heavy plow. I've heard say they don't make 'em like they used to. Not sure if that's true. The owner let me take it home to try, and I actually mounted it on my tractor. I was able to get it hooked up nice and straight, and I think it will work. I dropped it into the ground for a couple feet too, which is why it looks a little dirty. I didn't have quite the down pressure on it, but it seemed to want to go down if I were to adjust it.
Any opinions? It will have a pretty easy time of it. I'd be using it in a 1/2 acre hayfield, soon to be a small pumpkin/corn plot. Clay, but zero rocks. I can't really tell if the point and shin are worn too much, doesn't really look it. Not sure what's going on with the back end there. It almost looks like it is missing something at the end of the beam. Is that be where the trip would be? I can't tell if that second, upper bolt is a shear.
I'd welcome any thoughts. I'm new to plowing. That's my tiller in the background which I've already used in the space I mentioned. I just can't get down quite as deep as I'd like, and I'd want to start turning a cover crop in the spring. I'd like a little plow. You think this one is worth it?
   / Deere Plow - Oldie but Goodie? #3
If it had any other paint color, it would be a $150 plow. Let's see, $500, shear bolt trip, no parts availability. Not for me.
   / Deere Plow - Oldie but Goodie? #4
I gave $300 for a two bottom 415 four years ago that was in good shape. bjr
   / Deere Plow - Oldie but Goodie? #5
Last auction I went to sold a 3x16 for $95, there’s just no way that thing is worth $500 to me. For what you’re doing, a new middle buster for $150 would work.
   / Deere Plow - Oldie but Goodie? #6
Here is a IH 300 series plow with all the bells and whistles and wear parts showing almost no use. Lot less than $500. Ken Sweet
   / Deere Plow - Oldie but Goodie? #7
I have a 25 plow! Works great gave 150 fro it . Mine has a spring trip on it an the coulter wheel[/ATTACH]
   / Deere Plow - Oldie but Goodie? #8
That is a real nice plow with all the extras. I would value that plow at $400 +. The other JD 25 looks like it may be missing the trip? If that is the case, that alone drops its value considerably. Ken Sweet
Yep, I think the trip must have been an extra on this plow, and the depth control too. I'm assuming that bolt on the one I'm looking at, in the other hole, must be a shear.
Well, you've all made it pretty clear $500 is way too much. Thanks. I guess I'll pass on this one. He's a neighbor of mine, so it was too easy I guess. You don't see that many single bottoms for sale up here. I've been watching Craigs List for over a year. The few I've seen are always $300 or more, and it's impossible to tell their condition without getting in the car and driving an hour or more.
   / Deere Plow - Oldie but Goodie? #10
Agree the $500 price is high....although it does have green paint. :D
But it makes my one bottom Dearborn I paid $50 for a bargain.
I'm thinking parts would be more available for the old Dearborn plows (and similar) than for this Deere 25. Could be, the same parts would fit. But this one appears to be missing too many crucial parts...coulter and depth wheel just a couple of them.
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
Club Car Carryall 1500 Diesel Utility Cart (A53421)
Club Car Carryall...
