Dif-lock, I never use it?
   / Dif-lock, I never use it? #11
Never read a Kubota manual but on JD and Ford Ag tractors it was never a good idea to engage the diff lock with one wheel spinning and the other not. Can put a LOT of strain on the drive train. Maybe Bota's are made different but I doubt it.
Roy
   / Dif-lock, I never use it? #12
Just had to use my this weekend when I was using my grappler clearing trails,I would have been in trouble if not trying to get out .Don't worry you'll need it when you least expect it and you'll be gald you got it.
   / Dif-lock, I never use it? #13
Take care if you use differential lock on a side hill. If you spin one wheel on a side hill, the non-spinning wheel will hold your direction. If you spin both wheels on a side hill, gravity will have its way with the tractor (and you).
   / Dif-lock, I never use it? #14
Roy
I never engage diff lock on anything if a wheel is slipping.
   / Dif-lock, I never use it? #15
I use mine most of the time while brush hogging. The mower will go down in a small dip and the cutter frame will drag. For me the differential lock works better than engaging the 4WD.
   / Dif-lock, I never use it? #16
I use the differential lock all the time (daily) cause I have turf tires! It makes a huge difference.
-Jay
   / Dif-lock, I never use it? #17
I use mine all the time on the hills. If you are going down a steep hill that is fairly straight but steep it keeps both rear wheels holding back even if the slip a little. When engaging diff lock make sure you are not spinning your wheel then put a little pressure on the diff lock pedal and as you start applying a little power you will feel it engage, then let up and drive straight forward or as straight as you can. When the diff lock is engaged your rear differential is out of the picture.
   / Dif-lock, I never use it? #18
I once got stuck on 2 wheels while using the rotary with my MF. rocking back and forth on one front wheel and the opposite back wheel like a teeter toter. I forgot about the diff lock for awhile, and the two drive wheels were in the air. Was easy to move once I remembered. The tractor was pretty new to me at the time, and I never had diff lock before. It saved the day.
   / Dif-lock, I never use it? #19
Never use it while turning on your lawn:)
   / Dif-lock, I never use it? #20
I use mine along with 4wd when scooping dirt or anytime one rear is spinning.
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
Deere 331G (A50120)
Deere 331G (A50120)
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
