Question about footings
   / Question about footings #1
kcir
Lake Fork, Texas
Kubota 5400
I am wanting to build a 20x40 concrete pad 4" with a metal roof only, no sides. What kind of foooting do I need around the peremiter? 12"X12", 18"x18"?
I am in east Texas so no frost/freeze. Does anyone here know?
Thanks,
Rick
   / Question about footings #2
What kind of soil? Compacted or loose?
   / Question about footings #3
The footing size would be determined by the loading.:D
It's a hard sand, not red sand the yellow sand. Loose sand will get very hard here after a good rain. So sand/clay.
   / Question about footings #5
check with local contractors and see what is the norm for the locaton...
   / Question about footings #6
With "no sides" on your structure all the weight will be bearing on your posts,right? If that be the case,you do not need a perimeter footer.
   / Question about footings #7
Thanks,
Rick
Posts in the ground or on the slab?
   / Question about footings #8
It should depend on the two above. I just poured a 12ft X 28ft foundation a couple of weeks ago and we went 18 inches wide based on the soil and building load.
   / Question about footings #9
Mousefield:
Just curious, what is the slab inside the one end of the footing for?
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2022 JOHN DEERE 6140M LOT IDENTIFIER 246 (A53084)
2022 JOHN DEERE...
Electric Concrete Mixer (A51573)
Electric Concrete...
