Barn Kits?
   / Barn Kits? #1
ETD66SS
Newfane, New York
Ok, I want to make a 40 x 60 barn, gambrel roof, with a nice attic space for a future woodshop.
I do not like pole barns, as eventually I want drywall & insulation. I plan to have in-floor heat zones in the concrete slab.
I would not drywall & insulate right away, but would do that at a later date. I have "filled" in pole barns before with studs to hang drywall a few times. I'm not interested in that type of construction.
Are there any metal barn kits that would suit my needs?
I know this forum seems to be pole barn central, so I'm interested in hearing the thoughts of those who have been there, done that, etc.
   / Barn Kits? #2
It sounds like you're looking for pole barn that isn't a pole barn. Getting a 40' width attic gambrel is going to be the hard part.
You might look here.
Pole Barn Gambrel Truss Kits – APM Buildings.
Or
Barn Plans - Blueprints, Gambrel Roof, Barns, Homes, Garage Workshops, Dormer Window, Cupola
If it were me I would be contacting local contractors that build barn/pole buildings and ask them for examples. I know I'm looking at 32'x48' with attic gambrel roof, and the trusses had to be special design to meet my needs.
Wedge
   / Barn Kits? #3
Maybe some type of red iron building
Metal Building Supply Inc.
   / Barn Kits?
Pole Barn Gambrel Truss Kits APM Buildings.
Or
Wedge
Hmm, maybe 40ft is a bit unrealistic...
   / Barn Kits? #5
It all depends on how they are made and how large of an area you want on the 2nd floor. My barn has 80' clear span wood trusses and the company says they can do 120' clear span wood trusses. Of course the zone (snow load) and wanting to put in a drywall ceiling will have a huge impact on the project. My guess is that wanting to go with 5/8" drywall ceiling with a properly rated snow load bearing surface will make wood trusses out of the question. Then your steel trusses will likely make wood posts out of the question for side walls. From what you're describing, it sounds like you're going to have to go with a steel building.
2008 Caterpillar 262C High Flow XPS Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
