nmu98
- Joined
- Jun 1, 2007
- Messages
- 1,132
- Tractor
- JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
My current 3720 with R-4's does 80 percent of the jobs I need it to do with ease. I use it to cut about 6 acres of alfalfa, till 5 acres for vegitables, cut around the nursury, and do odd jobs around the house. I live on 20 acres that is one of our fields. Our main farm is about 3 miles away.
What it does not do is pull any ground engaging equipment. I have a 6 spring tooth cultivator that It will not pull. I have a 6 foot disc that it is useless with. My spring tooth harrow burries it... and sometimes I cannot lift pallets off my truck well.
My thoughts are to move up to a 4320 with r-1's and add some wheel weights. I will up my lift capacity by about 1200 pounds with the 400x. I hope to be able to pull the small ground engaging equipment??? I gain stability! I also hope to gain some longevity as I think this tractor is more of a commercial tractor??
Have any of you done this trade? Anyone have a 4x20 and know it limitations with drags on heavy soil? Any suggestions? My dealer is giving me a pretty good deal since he has little on his lot and wants to move some tractors.
Talk to me.
ON Edit. I see that the 4520 with econ PTO is 2500 more than the 4320 and its 60hp instead of 48. Seems smart to go that way. That would be a big jump in HP for me.
Talk to me.
