Cub Cadet 7200 Backhoe Not Working
   / Cub Cadet 7200 Backhoe Not Working #1
Rastafunk
I have a 2003 Cub Cadet 7200 with a Woods 457 Backhoe. After a couple months of use, a line on the backhoe blew. I took the backhoe off in order to replace the hose and still be able to use the tractor in the mean time, and when I re-attached the backhoe, it no longer worked. I am not very familiar with hydraulics, but I know I hooked the lines up correctly. Any ideas why it no longer works? Do I need to bleed the system? Thanks!
   / Cub Cadet 7200 Backhoe Not Working #2
Rastafunk,
I am thinking your quick disconnects are not fully engaged. Then again, maybe a relief valve blew and stuck in that position.
hugs, Brandi
   / Cub Cadet 7200 Backhoe Not Working #3
There is no need to "bleed" the system, just moving all functions from lock-to-lock will do that.
Does the engine sound labored at all? Like Brandi wrote, recheck all the connection again.
   / Cub Cadet 7200 Backhoe Not Working #4
I would encourage everyone using hydraulics to install a hyd gage in the hyd system, to know what is normal and not normal.
   / Cub Cadet 7200 Backhoe Not Working #5
JJ,
That is a good idea, but how does it relate to his backhoe not working now?:confused2:
Brandi
   / Cub Cadet 7200 Backhoe Not Working #6
Because you will know when you have pressure to any circuit, and how much.
QD's unlatched could shut off pressure.
In a complete BH circuit, the fluid flows through all valves in line, including the BH control valve, and then to tank. If pressure builds up on the gage, when you move a BH lever, then you have pressure, hopefully enough.
   / Cub Cadet 7200 Backhoe Not Working #7
I've done this myself before. 99% chance of the quick disconnects not connected properly. They might LOOK attached....and FEEL attached.....but they're NOT attached.
   / Cub Cadet 7200 Backhoe Not Working #9
I should have said shut off hyd flow.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
2015 Ford Expedition EL SUV (A51694)
2015 Ford...
Deere 333E (A50123)
Deere 333E (A50123)
2012 Mitsubishi Outlander Sport AWD SUV (A51694)
2012 Mitsubishi...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
