What Brand Bush Hog is This?
   / What Brand Bush Hog is This? #1
robertwhite
Can anyone tell what brand of Bush Hog this is and is it worth $400?
It is a 5ft hog and the owner says it works perfectly.
   / What Brand Bush Hog is This? #2
What are the letters you can make out on the white side decal. That may help? What do you need for it? Ken Sweet
   / What Brand Bush Hog is This? #3
Mr.Sweet trying to help poster like you.To me first three letters in center pic look like "har",like in Hardee.Hardee sells/makes red bush hogs,built in Loris,SC.I don't know mdl#,years,etc.Just trying to help.:)
Boone
I can make out just what you can which is why I thought maybe someone would recognize the logo.
What do I need for it? Don't understand what you mean, but I need for it to work to be able to hog 7-8 acres.
   / What Brand Bush Hog is This? #5
I thought you needed to know the Mfgr. so you could get some part you needed to get it going. We have a lot of parts that will work on that cutter, no matter the brand. Ken Sweet
Oh, gotcha now.
No just looking to see if it is some off brand junk or a decent deal.
   / What Brand Bush Hog is This? #7
It looks sturdy enough from the pics. Is the gearbox leaking oil? Why is there a strip of white tape on the corner of the deck? Is the wheel assembly/forks straight or bent (I mean bent, not "built to sit at an angle") Also, this looks like a shear pin unit. If you are doing mostly grass and light brush, this is probably OK; if you are hoggin down heavier brush, small trees and/or working on land with lots of hidden obstacles (rocks, pieces of iron, etc.) you might want to hold out for a unit with a slip clutch (or be prepared to retrofit), otherwise you'll be off and on the tractor to replace pins.
BOB
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
