L4610- Really excessive blow-by
   / L4610- Really excessive blow-by #1
rutwad
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
Kubota L4610 has approx 900 hrs. Lots of white smoke and oily residue coming from valve cover vent line. Starts shortly after running. Air filters clean, engine runs fine. Could this be something simple, or engine trouble?
   / L4610- Really excessive blow-by #2
Not likely very simple. Head gasket or cracked head or cracked block or..........sorry not good news:(
   / L4610- Really excessive blow-by #3
From the breather tube, I'm guessing dusted motor. I would check the intake hose, clamps, intake manifold, or gaskets after I did a compression test. Rarely do Kubotas have this type of issue that is a factory defect. In the 12 years I spent as a mechanic in Kubota dealerships I saw 2 engine failures that were Kubota's fault. Only one with symptoms like yours. It was a failed intake gasket. I have also done engine rebuilds on engines with as few as 80 hours because the owner never checked the air filter. Typically if this was a head gasket, head, or block issue you would have white smoke coming out of the exhaust. Before I got too carried away with guessing, I would do a compression test and a cylinder leakage test.
Brian
   / L4610- Really excessive blow-by #4
That would sure help finding the problem.:thumbsup:
Doesn't sound good. At least I have some ideas to start looking. Thanks.
I noticed pretty heavy black smoke coming from the exhaust when I first cranked it.
I need a non-technical explanation to help me understand. The vent tube is connected to the valve cover. Isn't there typically oil with the valves? Why would it not smoke under normal conditions?
If the rings were bad allowing compression to escape into the crankcase, is there a place that it could vent?
   / L4610- Really excessive blow-by #7
Yes, back up the oil galleries and up to the valve covers.:D
:thumbsup: easy enough
THANKS!
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
