buying a kubota l3400
   / buying a kubota l3400 #1
kubmike
hi i am new to the post. this weekend i am going to look at a 2008 l3400 hst tractor with 26 hrs. is there anything i should be concerened with?
   / buying a kubota l3400 #2
Since I just sold a 2008 l3400 with 26 hrs, I have to ask where are you from???.
Is it from a dealer?
   / buying a kubota l3400 #3
I am not aware of any problems with the L3400. I am sure you checked all of the fluid levels before buying. Your first service will be at 50 hours.
i am from rhode island and the tractor is in connecticut at a dealer.
   / buying a kubota l3400 #5
Let me guess,...
Is it,... Westview Tractors???
   / buying a kubota l3400 #6
I would make sure to test Everything out, attach an implement, and do minor adjustments to the three point hitch... make sure you like it. Nothing major you have to look out for... Seats tend to stick, Tie rods are exposed... What kind of work do you plan to do???
   / buying a kubota l3400 #7
If it's at Westview, it was mine.
So if kubmike wants to know anything, let me know.
   / buying a kubota l3400 #8
Only two major things to check, and maybe ehchvac can answer if it was his tractor:
1. Older 3PH used an inching valve which is jerky if trying to make small adjustments.
2. Hydraulic suction hoses had a problem with cracking. Newer ones are an updated hose. It may have already been fixed or may be new enough to not have a problem.
   / buying a kubota l3400 #9
So did you get the Tractor??
2 posts and we havent heard back in over a week??
   / buying a kubota l3400 #10
ehchvac...
Just curious--- why did you trade after 26 hours??
J
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
199049 (A51243)
199049 (A51243)
Mini trencher attachment (A53421)
Mini trencher...
