Buying Advice Good/cheap drill press for making 1/2" holes
   / Good/cheap drill press for making 1/2" holes
Ok my real problem was two things, one my speed was two high and set it to 250 rpm and I bought new drill bit "hitachi" really good it was on sale. I was able to make 1/2 " hole under and minute and I like the HF drill press.
Just wanted to update my thread
Ganesh
   / Good/cheap drill press for making 1/2" holes #43
Good deal smokey.
Now keep your eyes open for that old used Bridgeport. I been looking for 20 yrs but haven't found the right DEAL yet.
   / Good/cheap drill press for making 1/2" holes #44
Good deal smokey.
heck with a 20 year wait. i had been looking for a good heavy used drill press for 1" and larger holes in steel. i think i gave up after about 15-18 months. ended up driving 170mi to the next state to buy a used mill/drill.
   / Good/cheap drill press for making 1/2" holes #46
Good deal smokey.
They may not look like my 2 year old Hardinge/Bridgeport with 3 axis Newall DRO, however, there are many, many old Bridgeports out there... Going to be lash in the X and Y and will without question need a bath, however, they are out there for those with the will. Few knock on doors and beg for a home though... Been waiting on a Monarch 10EE to do that and I to have been disappointed FOR YEARS. I often run to the door only to find another Jehovah's Witness... Group sigh...:)
Regards, Matt.
   / Good/cheap drill press for making 1/2" holes #47
keep some oil on the bit and it will last longer
soundguy
   / Good/cheap drill press for making 1/2" holes #48
Glad you figured out the speed thing. Go to the plumbing section and get some thread cutting oil. You can get a QT for maybe $4 and it will last a long time. Keep the bit well lubricated and go slow and you will be pleased.
By the way almost all DP I have used have you change the bets and pulleys to adjust the speed.
Remember slow and steady. Once you get the bit smoking its shot.
Chris
   / Good/cheap drill press for making 1/2" holes #49
mjncad,
You are likely right, however, have you seen what old belt drive Bridgeports often go for?...
There are a half dozen of them in the Boston area CL now. $1300 -2000 asking. Most look in good shape and have the two axis DPO but at least one has the 3 axis DPO
   / Good/cheap drill press for making 1/2" holes #50
Variable speed drill presses are out there; but they are pricey. Powermatic has floor model one for around a grand; but the thing is made in China.
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
Alligator Statue (A55853)
Alligator Statue...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
