To cab or not to cab?
   / To cab or not to cab? #1
scrimshaw33
JD 4520 w/ cab and FEL
I can get a cab on the desired tractor I want or I can get one without. Any reason not to get one? It's about $2500 more for the cab with heat and air. I like the open air feel of tractors and for me this would be the only downside, but I can see during hot days like we have now (and cold ones) where a cab would come in handy. Is this a no brainer...get the cab?
   / To cab or not to cab? #2
With no mention of what you intend to use the tractor for (primarily), we can only leave it up to you. Personally, I would never justify $2500 for a cab unless it was used primarily for a row crop/hay tractor.
What I'll do with it...a little of everything like most people probably. Bushog, use FEL to move trees, plant food plots....etc.
   / To cab or not to cab? #4
I would have loved getting a cab. Heat and A/C during winter and summer would be great! I can always open the windows if I want fresh air.
Here were my reasons for getting a ROPS instead:
Money. I would have had to give up other options to pay for the cab.
Storage. I have to fold down my ROPS to get my tractor in my garage. Eventually I will have a shed, but for now I have to use my garage. Keeping it outside is NOT an option!
Now that I have been using it (I just bought it a few weeks ago), I am even happier I went with ROPS. I have to manuever around many trees and I wouldn't have been able to get into areas had I bought a cab.
If you can afford it, store it AND don't have obstructions in the way... I say go for the cab!
   / To cab or not to cab? #5
For me, the dowside is missing out on getting real dirty every time I use the tractor. Or I could get cold and wet in the winter. Or I would have to worry about bees, or wasps, or allergies... Or I would have to listen to the radio while I work and be comfortable no matter the weater.. I would hate to miss out on all that, so I would never get a cab.:D
   / To cab or not to cab? #6
Awesome!
   / To cab or not to cab? #7
Personally, I would go with a cab.. However, I have nearly 600 hours on my 110 in 2 years use. And, I've just taken on an additional 10 acres of hay ground - that needs to be fertilized twice per season, sprayed for weeds 1-2 times per year and mowed, raked, tedded, and baled.
So, the tractor hours will be adding up..
If you can afford it and expect to spend a fair bit of time using your tractor when it's hot, dusty, or cold, wet, and windy - buy the cab!
You won't be kicking yourself every time you turn up the AC or dial up the heater! But, you will be grumpy every time you crawl off that seat and every joint is stiff with the cold or sticky with sweat!
AKfish
   / To cab or not to cab? #8
There is nothing like burning up or freezing to death! Speaks for itself.:thumbsup:
   / To cab or not to cab? #9
I can get a cab on the desired tractor I want or I can get one without. Any reason not to get one? It's about $2500 more for the cab with heat and air...
Switched around, do you have any reason to get a cab? Also what factory cab with heat and air is only +$2,500.00?
   / To cab or not to cab? #10
Cabs, like HST, are for the girly boys...unmanly men who cannot hack real life.
Other then that, I'd be concerned about all that weight above the axle unless those tasks were as MMagis wrote...row crops and such like that which are on mostly level areas with no obstructions. The 3720 series machines (which is what I think scrimshaw33 is going to buy) are known for that tippiness.
So scrimshaw33, if you do give up your testicles and buy a cab (after all, it is your money)...get those rear tires filled and at the widest position.
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
44023 (A51692)
44023 (A51692)
2005 GENIE Z-34/22 ELECTRIC TELESCOPIC MANLIFT (A51246)
2005 GENIE Z-34/22...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
