Transmission and hydraulic Fluid
   / Transmission and hydraulic Fluid #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
In the DK45S shop manual they show the same picture for hydraulic and transmission points of refilling. This is at rear of tractor next to 3 pt hitch - red plug with hook. Is this where I top up the hydraulic fluid? I pulled the dip stick and it is reading low - to lower right of refilling tube - which by the way could be redesigned!
May be a stupid question but manual is loosely accurate.
TIA
   / Transmission and hydraulic Fluid #2
TIA
Yes the red cap with the hook is where you top off the hydraulic. I have the 45SE HST model. If I understand correctly, both pumps use the same reservoir but have different filters.
OK.
Looked further in the manual... and found it.
Thanks. Better safe than sorry!
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2019 Komatsu WA470-8 Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Diesel Engine, JRB (A59076)
2019 Komatsu...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
