520H only runs on 1/2 choke...
   / 520H only runs on 1/2 choke... #1
monkers
I have a 520H with an Onan engine and had thought the fuel pump was bad earlier in the seasnon, now the engine surges unless you use 1/2 choke, i checked the gov adj like the book says and it was fine, dirty carb? Thanks
   / 520H only runs on 1/2 choke... #2
I would start by cleaning the carb. Sounds like there may be some debris in one of the jets causing it to run lean.
Roy
Thank you
   / 520H only runs on 1/2 choke... #4
I found taking the air filter off for access to the carbeurator and using compressed air to blow out every orifice you can find will clear the carbeurator and it will run fine. be careful you will spray out gasoline, atomizing it, making it highly explosive. I had to do this on two occasions and on two different 520H's and the tractors runs fine now. Beats taking the carbeurator off and cleaning it.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
