1920 Fuse location?
   / 1920 Fuse location? #1
2dawoodz
New to tractors. Replaced the battery. No power to instrument panel. Where are fuses located?
   / 1920 Fuse location? #2
check yer manual. I had a 1920 10ys ago.. but can't remember where the fuse panel was. follow the wire coming off battery hot.. one will go to start solenoid.. from there there is usually a smaller wire.. perhaps 10 or 8 ga that runs to the power distribution center. on that small tractor it should not be to hard to follow it up. the dash and cowl area just ain't that big. prime locations would be lower r or l side o f the dash cowling.
soundguy
   / 1920 Fuse location? #3
here is your electrical diagram
the inset pic int he middle at the top is the end of the wire harnes with intergral fuse block
#16, etc...
soundguy
Thanks Soundguy. The owner does not have a manual. I checked the 3 fuses in #16 diagram. All look good. Now for the bad news. I believe I connected the battery wrong. I thought the red cable was positive and black was negative. However, the red cable is connected to the frame and the black cable is connnected to the starter. Hopefully there are other fuses that I have cooked and not something more serious/expensive. Again, thanks for your advice and assistance.
   / 1920 Fuse location? #5
if the battery was hooked up wrong.. I'd have the alternator tested.. they don't last but about a second before the silicone parts die..
soundguy
   / 1920 Fuse location? #6
And address the problem with the color coding. The red definetly should be the positive.. Sounds like someone changed it around
   / 1920 Fuse location? #7
There is a fusible link attached to the starter solenoid on the terminal with the battery cable. It is a 3" red wire with an 8MM eyelet on one end and a white plastic connector body on the other. If it is open, you will have no power to any accessory or control circuits, including the instrument panel.
All other comments about alternators and battery cable color coding apply.
Is checking the fusible link something that can be done by just a visual or will I need some type of meter or testing tool?
   / 1920 Fuse location? #9
Please don't take this personally. After reading your posts; I would have a qualified mechanic look at the situation. Reversed battery hookup and if you need any type of equipment to test a fuse link tends to lead me to having a qualified person look at this.
I admit I feel pretty stupid connecting the battery wrong even though the the cables colors are incorrrect. I was hoping to learn enough to correctly diagnose whether the fusible link was the problem and admit I am not familiar with testing electrical problems other than using a a simple test light or checking fuses visually. I'll keep researching and if I don't get anywhere I'll start looking for a mechanic.
DESK (A53843)
DESK (A53843)
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
