JB Weld re. Aluminum
   / JB Weld re. Aluminum #1
3930dave
Super Member
Canada
Ford 3930
Hiya,
Not trying to insult real welders with a JB post here.....just wanted to get this question in front of people who have been playing with metal for "a while".
I need to fix a minor problem on the exterior of an aluminum head.
A wise wrench I trust recommended JB for this fix (makes sense to me), but also added that I should look for the JB version that is optimized for Aluminum.
Looking at the JB site, I can only see their generic version listed. The generic JB is listed as working on Aluminum, but I don't mind chasing down a better version.
Is my buddy remembering a variant of JB that doesn't exist anymore, or is it a industrial product that is not listed on their public site ?
Best Rgds, Dave.
Thnx for the note WP..... I've liked the Permatex products I've used the last # of years, looks like Devcon is the same corp.
The name rings a bell, but it was many years ago I would have used a Devcon product, so am not familiar with the current offerings.
Their site does list an Aluminum epoxy, I'll try to find it locally.
Best Rgds, D.
   / JB Weld re. Aluminum #5
The best I have used and sold is called Lab-Metal. Also a product sold by Harris called Super-Weld. Lab-Metal is the only one ( as far as I know ) that contains Metal pigments. It sparks when you grind it. It still may be Epoxy Based like all the others. All you need to worry about is expansion and contraction because of the heat. If the repair is in a combustion area, Tig Weld it. Or better yet, Tig Weld it anyway.. Good Luck..
Thnx for the options Yo.... the smallest Al. epoxy I've seen listed is 1lb, and that is a "bit" more than I need, so will check yours out too.
The issue on the head is with something like a frost plug (same idea, just smaller, about the diameter of my pinky finger). I have a slight seepage, from the water jacket.
A buddy (who has worked on a bazillion of these particular engines) has recommended super cleaning the exterior aluminum (he has the right tools) and filling this area level with a good Aluminum epoxy. Seems a reasonable approach for me to pull off, given an epoxy that is a thermal/chemical match for aluminum.
I want to try this epoxy approach, b4 trying to physically replace the plug.... don't have the resources to get into any serious welding/machining at this time.
This old engine has been good to me.... just hoping to keep the coolant where it can do its job..... :thumbsup:
   / JB Weld re. Aluminum #7
Have you tried adding Alumaseal to the coolant system ?
I have had good results with it on aluminum.
E/S
   / JB Weld re. Aluminum #8
I always clean with denatured alcohol right before applying anything. Aaron
   / JB Weld re. Aluminum #9
This JB Weld against Devcon thng stirred my curious up so I went looking at both websites.
Now Devcon does make a lot of different epoxys, I know their bronze one has made a good number of emergency bearings to get machines back running when the bearing was a month away, but when you get right head to head JB - Devcon, JB Werld comes up a winner.
JB has a higher temperature range, and is equal in strength to Devcon.
About the main drawback to JB weld is those dang little tubes don't seem to be big enough for the job at hand.
Then again once you open up a can of Devcon the second time to use it the dang stuff is a rock in the bottom of the can.
   / JB Weld re. Aluminum #10
We use Devcon for industrial repair of castings. And have done this for decades. We wouldn't even consider JB Weld. We would have no reason to.
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
