Major Driveway Project, Opinions Please
   / Major Driveway Project, Opinions Please #11
Welcome, Don.
Personally, I would work with the material on hand first. It may very well end up being enough. It looks like there is alot of material that has been pushed out into the grass.
With a little time, you can do alot with a box blade. Adjust the 3-pt hitch arms so that one side if lower than the other. You don't have to spend money on a tilt model.
Where in AL are you located?
   / Major Driveway Project, Opinions Please #12
I'd work what you have where you can first, then add some crusher run and work that. Of course, where you see the exposed shale you can't do a thing. I don't see any way you won't have to add some gravel. When you add the gravel, it will eventually take the contour of what you had before. So if you can smooth things out before you put the gravel down, it will work better when the gravel packs down. A 12 ton load of crusher run spread thinly will get you about 400', but realize this is a huge YMMV guesstimate as trucks haul different quantities and drivers have different skills regarding how they spread the gravel.
The trees around the driveway are a good distance off to the side, that's good. You'll want to have a 12' wide by 12' tall box for fire and UPS. Now if you're going to have a truck do a tailgate spread of the gravel (IMHO the way to go), you'll need to have clearance up to about 18 feet so the truck can drive with the bed up in the air. I saw just a few places where the trees were over the driveway and the branches were more than 1/2".
Pete
Welcome, Don.
Hi, Rut,
I am in New Site north of Alexander City. We have 80 acres of mostly hardwood here with the house plopped in the middle.
Don
One more consideration, we are slipping into drought here. Do the rippers on a box blade work better in wet soil? Should I wait for rain or just work along as I can?
Don
   / Major Driveway Project, Opinions Please #15
I agree with the group that says your road is in great shape for a road without maintenance for 12 yrs, and must have a good base. I would get
a 6' rear blade or 5' box blade and forget about buying new material to start.
Learn to use your new impliment on small sections that are most easily worked. Learning as you go. Stay away from scarifying in the begining. Just make small cuts. If you tear up the road base by scarifying you might have a lot of trouble getting it back as good as it is now. You will be surprised what you can make that road look like a little at a time. After you have a feel for dirt work go after the places where you have water problems. Either standing water or erosion. If they can't be fixed get some material. The idea that a crown isn't necessary and that a flat pitch to one side is just as good was very good advice.
I believe a stout rear blade with tilt capability is the most universal road tool but the box blade isnt far behind.
Have fun with it and good luck.
The box blade came Friday. After much fun learning to swap 3 point hitch attachments, I went for a test drive. It does about what I thought it would.
We had a big rain and now I know the answer to my question above. If it's to wet to plow it's to wet to boxblade. Everything wanted to clump instead of flow. I will wait a day or so and try again.
   / Major Driveway Project, Opinions Please #17
Very good advice IMHO ...... why tear up a good base that has been packed down over what - 12 years ? .... when all you need to do is a little surface/top work ?
+ 1 ...... did it on a large section of my drive and it has worked very well.
I'll also second eepete's comments on using crusher run - when I built our new driveway I used no. 2's and crushed asphalt from the old driveway over geotex fabric topped with crusher run, which worked it's way into the voids in the no. 2's/asphalt.
Once this material was packed down and consolidated, it (the crusher run) is like almost concrete when dry ...... and very stable even when wet.
   / Major Driveway Project, Opinions Please #18
And you may know or it may be already mentioned, but adjusting the top link attached to the box blade can make huge differences. It can lightly drag across the top, or cut into the surface depending on how it's set.
   / Major Driveway Project, Opinions Please #19
I have a B3200 virtually the same as your tractor and i run a 6ft. box blade with no issues. I build/grade gravel driveways in my business, I wouldn't hesitate to buy a 6 footer. Try grading with what you already have existing and add if you have to as said above. And yes, you can adjust 3 pt lifting arms to adjust tilt for a slight slope. Good Luck.
   / Major Driveway Project, Opinions Please #20
A lot of good advice given. Especially advice to stay away from scarifying sure seems prudent here. You are lucky to have a very good shale base in most places and the rippers could make of mess of that. The shale is best level undisturbed.
I do see a few places where it looks like it gets pretty soft during wet periods. In those, you might want to consider geotex before graveling. But, I'd certainly come to know the road conditions during both wet and dry times before I would invest in much new materials. You might also need some small culvert pipe in spots to carry the water away.
I think you need both a box and a scraper blade. The scraper will allow you to more easily pull gravel from the shoulders back onto the road. The box is real nice for spreading and leveling. Used scraper blades are easy to find on Craigslist. A rake with wheels might also be nice, especially if you stay thin over the shale.
And if you want a nice groomable road above the shale, you are going to need a lot more gravel than you think. Nothing wrong with staying thin over the shale, as it won't move or get soft. But, aesthetically, you'll need a good 4-6" above the shale for a nice looking uniform-textured road. The good part of that is that it gives you enough matieral to easily groom and keep nice for years to come. I think that if you just stay thin over the shale, the gravel will wash out during heavy rains where it's sloped because it will be difficult to contour for optimum run-off. Not real easy to shape hard rock.
I just built a road 300 feet long. It took 150 tons of CNR/57's to get a good 6" base. It's beautiful though and stays in place. Even though it's steep in spots, there has been no erosion during heavy downpours.
2007 JLG SkyTrak 10054 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
General 7000 EXL 7000 Watt Generator (A50322)
General 7000 EXL...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
