Rear mounted sickle mower hydraulic lift
   / Rear mounted sickle mower hydraulic lift
I'm not sure what you mean. It acts like a hedge trimmer. It has a single cutter blade with teeth that go back and forth across fixed guides.
   / Rear mounted sickle mower hydraulic lift #12
Sounds like a double action type, where the guard moves in and out as well as the sickle bar moving in and out? Ken Sweet
I guess it is single action. It has a cutter bar with teeth that look like shark's teeth, but flat. It moves back and forth across guide teeth that are fixed in place.
   / Rear mounted sickle mower hydraulic lift #14
Yes, that is conventional single action style. Let us know how you like it. Ken Sweet
   / Rear mounted sickle mower hydraulic lift #15
What all do you plan to cut? Are you haying? Trimming pond?
I'd like to see some pic's showing the clearance between the cutter frame and your tractor's parts.
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2025 AGT M-BKM (A50123)
2025 AGT M-BKM...
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
