Turn switch on several times before starting--Tractor
   / Turn switch on several times before starting--Tractor #1
sourwood
Member
North Carolina
Farmtrac 665DTC, Zetor 7711, Long 460, Long 310, Satoh S370D, Iseki 4100F, Case 380CK, John Deere 420C
I have a 2006 Farm Trac 665DTC, shuttle shift, 12 speed.
The switch has started clicking several times before it actually engages and cranks. By clicking I mean you must turn the key to the start posiion several times before it will engage and start.
Would someone educate me on possibilities and ways to check?
Thanks
   / Turn switch on several times before starting--Tractor #2
My first step would be to redo all 4 points of your high amp leads. Period. Even if they looked good.
If that didn't do it, I'd move to your key switch connections.
   / Turn switch on several times before starting--Tractor #3
clean and tighten battery connections first, be sure battery cables are clean and tight on starter and ground, check wire connections at key switch and starter solinoid.
With the tractor out of gear you can use a jumper wire direct from the battery to the switch terminal on the solinoid, if the problem goes away, that indicates a switch/wiring issue, if the problem still exists, solinoid or starter are suspect.
   / Turn switch on several times before starting--Tractor #4
If you try this, make sure its in nuetral or you may run yourself over with the tractor.
   / Turn switch on several times before starting--Tractor #5
Normally, in cars, this is a symptom of a problem with the contacts inside the starter. Partiularly Japanese cars with the little gear reduction starters.
This explains it on a Toyota: Starter Contact Repair
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
