which rear blade to buy?
   / which rear blade to buy? #1
GaryS
Gold Member
franklin park, pa
Kubota L3901 & LA525
Anyone have recommendations on a rear blade? I have a cheap noname blade and the snows from last winter caused it to break. Instead of fixing it and having it break again, I want to buy one that will last.
I looked at the Woods RB72 but there have been some negative threads about it. I have had great experiences with Woods finish & brushbull mowers and I think it's all made in the USA which is a huge plus.
What recommendations do folks have?
   / which rear blade to buy? #2
get a good one and atleast a foot wider then your tractor so when you angle it you still cover tracks
   / which rear blade to buy? #3
I got a woods rbe5 and its way too light weight for my use. I thought it looked flimsy when I bought it but had no experience and I went cheap. I've pretty much bent it straight now. I'm going to use it for snow in the winter but will buy a heavier blade for road work. I think the problem is my tractor (Kioti ck20s) is relatively heavy for its HP and the blade I got is from the Kubota dealer, which have a lighter tractor in that HP rating.
   / which rear blade to buy? #4
If you don't mind driving a few hours to the York, PA area (south central), I have a very old, but very heavy rear blade I'm selling. It's not pretty, but it's right heavy duty.
Don't ask for pics though...
   / which rear blade to buy? #5
We have had really good service from Land Pride and Woods equipment, but I don't know about their blades. We have a 7' King Kutter that has held up to some pretty rough use.
   / which rear blade to buy? #6
I have the Woods 5 ft RB60. I have moved a lot of snow with that sucker.
I'd buy another one in a heartbeat.
   / which rear blade to buy? #7
Great advice all ready given above.Here's names of companys I would consider.Befco-Rhino-Woods/Frontier-Landpride-Bison-BushHog.Sounds like you did TBN search already for info.
Not saying it's the best,but here are a couple pics of my 1958 SERVIS(RHINO)manual controlled:D rear blade.
Boone
   / which rear blade to buy? #8
I have a woods 6' one that has done what it needed to, but now sits in my backyard rusting. Ever since I bought my boxblade, I almost never use the rear blade. Don't know if I ever will.
Be careful when buying a "named" brand. Woods and others make several grades of blades like econo or home user, medium, and commercial/industrial. They of course vary in price according to the heavier duty quality. So, a 6' brand "x" may be $100 less than a 6' brand "y", but they may not be of the same strength/durability.
   / which rear blade to buy? #9
Don't forget to check craigslist in your area. The pittsburgh listings are loaded with stuff in there. I scan the Pittsburgh pages every once in awhile when headed to mercer.
   / which rear blade to buy? #10
Good advice, I second what Duckhunter said. get at least 1 foot wider then tractor. I also found that painting the balde with snow plow paint ( bought mine @ TSC) makes the snow slide off it much better there for pushing heavy show is alot easier on the tractor. Plows may come with this type of paint new but since i dont by anything new i dont know. The blade i have is heavy duty dont know the make but it was built in Cal. one of the only good things to come from that state if you ask me.
LOT LOCATIONS (A54313)
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
