Farmall A
   / Farmall A #1
husqvarna
Alto, Michigan
John Deere 400 Backhoe Loader, 1945 Farmall A, 1941 Farmall H, eXmark 27HP Lazer Z
Just baught a Farmall A and I'm wondering how to tell the year. Where are the casting stamps to look for? I think the serial number tag is gone. I was told it's a 1948 but I want to be sure.
   / Farmall A #2
I've restored several of the offset models. 2 A's, and a BN. As far as I know, the serial tag is located on the seat bracket attached to the transmission, is the only serial number location on them.
   / Farmall A #3
I stand corrected of a second serial number location... Don't know what I was thinking...
Look on the right front corner of the block, just above the mag, or distributor drive. There is a flat boss just below the head with the serial number stamped there.
You may need to scrape the paint off to see it, if you haven't already found it.
   / Farmall A #4
I never saw a second serial number on my old Farmall A; the only one was on the seat bracket.
My serial number indicated a 1941. I was able to look up the casting numbers on the tranny, torque tube, engine. They indicated Dec 1940 for casting, which figures about right for 1941 production/assembly.
   / Farmall A #5
I am in the process of restoring what used to be my father's Super A. Although my original serial number plate is intact and I found the number there (indicating its a 1948 by serial number), during the restoration I discovered a manufacture date stamped on the top of the cylinder head.
08-17-48
   / Farmall A #6
08-17-48
I was searching online to trying to locate something that would tell me what year my Farmall A that I brought home today was made...the ser no. plate under the seat mount was missing and the guy told me it was a 1948....Having been misled on my 1948 H by the past owner ...He was convinced it was a 1940...I wanted to confirm the year of the A that my son and I drug home today myself...I ck鐡 on several sites to locate something I could use to identify the year without much luck as the casting numbers led me to believe the A was a 42...then I found this post and...Wamo...There It was behind the coil...just where its supposed to be...Thanks to All !!!!!!!!!!!!!!
   / Farmall A #7
:thumbsup:
   / Farmall A #8
I just got an A, ---no tag either and have not had time to look for casting #'s yet !
On my Super A , the tag is under the seat and good tag! thanks; sonny580
   / Farmall A #9
I just resently aquired my great grandfathers Farmall A.. y uncle said it was a 1948, but i think it is older. I can't find a serial number anywhere. The only thing I found was some casting numbers. I did find 3*8*J ( looks like a J ). is that the casting date? All the help would be appreciated
   / Farmall A #10
this don't help ya but:
Farmall A (Includes AV)
Prefix Letters: A=FAA, AV=FAAV
SERIAL NUMBER.......................................YEAR
501 - 6743.........................................................1939
6744 - 41499.....................................................1940
41500 - 80738...................................................1941
80739 - 96389...................................................1942
no official production........................................1943
96390 - 113217..................................................1944
113218 - 146699................................................1945
146700 - 182963................................................1946
182964 - 198298 (Chicago)...............................1947
200001 - 220829 (Louisville).............................1947
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
Navigator 4000 4,000lbs Forklift (TRUCK MOUNT) (A52128)
Navigator 4000...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
