Ray2210
I bought an ex grain truck that had the hoist removed and am in the process of putting a deck on it with a really good scissor hoist I picked up used really cheap. I really want the dump feature. I completely didn't notice that the pto pump that's still on the truck is double acting. The cylinder for the hoist is single acting and I'm not wanting to drop 300 bucks for a new one. I am no hydraulics expert.
The pump functions in a manner where when the pto pump is engaged there is pressure to either the extend or retract side of a cylinder. There is no neutral position so when you engage the pump it's one or the other. Generally when you engage the pump the selector will be in down. In such a case the pumps relief valve must bypass as it will when the selector is up and the bed reaches full height. When in up I have verified a clear return to the tank for the down side and vice versa. I have concluded from this that I can plug the down port on the pump and it should relieve and bypass internally just as it would if the bed was down with a double acting cylinder that was now bottomed out. When the selector is in the up position the up port will pressurize and the bed will rise and once again the relief sholuld bypass at the top. At this point I assume that I should be able, even with the pump engaged, to switch to down and the bed will lower with a gravity return and no harm to the pump. I should also be able to simply disengage the pump and let the bed return with gravity the same way. Am I missing something or are my assumptions likely correct?
