BCS 715 transmission oil check?
   / BCS 715 transmission oil check? #1
Ezzrider
Kubota B7510
As I stated in a previos post I just purchased a used BCS 715 that has a Kohler Magnum 8 engine. I am attempting to check the transmission oil but I can find no filler screw or any other place on the transmission area to check the oil level. There is a drain plug in the very bottom of the transmission and what appears to be some sort of vent rubber cap on the top of the transmission. The tiller runs fine and engages in all the gears but I want to check and replace the transmission oil. Hopefully it is not DRY! If so I got screwed. The former owner told me he did not know where to check the transmission oil and he has had the unit for 3 years. I does appear to run fine though.
   / BCS 715 transmission oil check? #2
That 'vent thing' is a dipstick. It must be installed with the flat side towards the middle of the tractor, or IIRC the gears will eat it.
Now that I have been able to remove and check the transmission with your help - When you say flat side towards middle of tractor when replacing the dipstick - that would be flat side facing the back of the transmission where the shifter is located and in your picture towards the right side of the picture?
   / BCS 715 transmission oil check? #4
No, the flat side should face towards the top of the picture.
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
1999 CHEVROLET C7500 UTILITY TRUCK (A53426)
1999 CHEVROLET...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
