Think I Bent My Grapple Cylinder
   / Think I Bent My Grapple Cylinder #1
wvpolekat
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
I think I may have tweaked the cylinder on my grapple.
In the middle of the travel it seems ok, but at either end it seems to bind up. This happens even with the cylinder removed from the grapple. On extend, if I pull I can get it all the way extended.
Visibly, it isn't bent.
A shop that can check it out is an hour away. Replacement cylinder runs about $80.
Is there anything I can do to verify things or should I just buy a new one?
   / Think I Bent My Grapple Cylinder #2
Pull the shaft out , and put a straight edge on it in about 4 different places. Maybe check the pins, and lube them.
   / Think I Bent My Grapple Cylinder #3
Once you have determined that the rod is bent (with a straight edge as JJ
suggests), you can straighten it with a press. Or have a shop do it. It
is very easy as long at the rod is not bent too far. I have done it multiple
times.
Honestly, I am not equipped to pull it apart. No workbench, vise, any of that.
I am thinking that the best thing to do is to just replace it. By the time I drive to a shop to have it looked at, pay for gas, pay them, I am at the same price as a new one.
I am 99% sure I bent it when I had it on the trailer. I put the strap for the loader over it, but I didn't think I cinched it down hard enough to bend it.
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Unused Delta Crash...
TEST BID LOT (A50774)
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
