Self Propelled Walk Behind
   / Self Propelled Walk Behind #11
it's getting harder and harder to find mowers that don't have bags
That's news to me, but I haven't really shopped for a mower in 3 years, but I think Toro still offers the "3-in-1" like I have; bag, mulch, or side discharge and I've used it all three ways.
   / Self Propelled Walk Behind #12
I haven't done a scientific study to determine the ratio of bagged to bagless mowers. Just based on my personal observations in the stores it seems only the cheap-o mowers are bagless and all of the expensive ones have bags. I've never owned a mower with a bag. Seems to me it's just extra work. :confused3:
   / Self Propelled Walk Behind #13
I think Bird is right, most of the mowers today are 3 in one types (higher priced ones)
   / Self Propelled Walk Behind #14
OK, I understand now. Yes, the cheapest ones sometimes don't have bags, but those that do have bags usually also have some way to use them without the bag. I definitely do want the bag myself. First thing in the Spring, I cut the grass just as short as possible, may even run the dethatcher over it then and go over it again with the mower with the bag. Then I fertilize and water. This time of year, I'm not using the bag, but I probably will when the leaves fall instead of raking leaves. When not using the bag, sometimes I mulch, but often I use the side discharge but mow in such a direction that the discharge is blown onto uncut grass instead of the cut grass. That means I'm going to chop those clippings again on the next round, so I get about the same result as mulching.
I don't let my grass get too tall, so this mower never sounds as if it's under any load at all, but I've mowed some for neighbors when they had let it get so bad that trying to mow in the mulching mode could bog down the engine; even kill the engine. So that's another time the side discharge is good.
In other words, during the year, I'll use all 3 modes.
   / Self Propelled Walk Behind #15
I have been of the opinion that the rear drive is better than the front drive. I haven't had personal experience with either, but have done a little research and that seams to be the gereral opinion from what I can find. I think the commercial mowers are all rear drive.
From what I've seen, the front wheel drives are usually cheaper. I've only owned rear wheel drive, but I've used front wheel drive mowers and don't like them myself. Of course, now we're talking about personal preference instead of one actually being better than the other.
A former neighbor, young lady, came over Saturday and while my wife was playing with her two kids, she insisted on mowing our yard. She's used to their Craftsman front wheel drive and when she was about halfway through mowing our yard with my mower, she said, "I like this mower!"
   / Self Propelled Walk Behind #16
I never had a rear drive so apparently don't know what I'm missing. With a front drive if you want to pause or go backward you just push down on the handle. There's no need to disengage the drive wheels. How does that work with a rear drive?
   / Self Propelled Walk Behind #17
Yep, that's the way the only front wheel drive mowers I've used worked; not bad. There are some different rear wheel drive systems that work different ways. Most of the ones I've used in the past were single speed and you pulled a lever or "bail" back to the handle to go, released it to stop or back up. That worked OK, but usually went forward too slow to suit me. But with my current Toro "personal pace" mower, you have an "upper handle" which can slide on the lower handle. The upper handle is what you have hold of and as you push forward the mower moves forward. The farther you push it, the faster it goes. So if you stop pushing, the mower stops. But the "pushing" I'm talking about is effortless, not like "pushing" a non-self-propelled mower.
   / Self Propelled Walk Behind #18
Bird that sounds like a great feature. My mowers go at their speed instead of the other way around. Downhill I have to almost run to keep up. :)
Toro - Homeowner Mowers
   / Self Propelled Walk Behind #19
Thats a good point. Never having had a front wheel drive I hadn't considered that. Rear wheel drive can be a little awkward to maneuver around tight spaces, but I still wonder how successfully a front wheel drive pulls up inclines.
   / Self Propelled Walk Behind #20
One of my mowers is rear drive and the other is front drive. It has been my experiance that the rear drive seems to maintain traction better than the front drive. No big scientific study just my personal opinion. :)
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2015 Chevrolet Impala Sedan (A51694)
2015 Chevrolet...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
