Oil & Fuel heavy smoke
   / heavy smoke #1
sbp30
I have a bx23, with a severe smoking problem. Already have swapped injectors, also if i unhook the #3 injector it quits. Tried unhooking the return but same outcome, heavy smoke.
Im thinking injection pump.
   / heavy smoke #2
I have a bx23, with a severe smoking problem. Already have swapped injectors, also if i unhook the #3 injector it quits. Tried unhooking the return but same outcome.
Now wait a minute I thought this varmint was a direct injection 3 cylinder engine?
You have a bad injector allowing too much fuel into the number three cylinder.
Leonz
   / heavy smoke #3
I thought this one was still indirect TVCS, but I could be wrong.
But what would that have to do with anything? Don't the direct injection engines still use a mechanical injection pump? Direct refers to the combustion chamber and injector design, not the pump technology used.
   / heavy smoke
Yes it is a 3 cylinder. It has a inline injector pump (p-pump if you are a cummins person).
It seems like the pump is injecting #3 heavily. No matter if i change the injectors around. If you disable #3 no smoke, of course it runs badly.
   / heavy smoke
pulled pump off, will post outcome of autopsy.
   / heavy smoke #7
Could you have a compression issue on #3 Vs a bad injector?
Roy
   / heavy smoke #8
I'd think that something is wrong in the three hole!!! Injectors are set to spray at a certain pressure, they also will carry a minimum pressure just below the blow pressure and I've not seen a injector pump through to much pressure to one hole before.
   / heavy smoke #9
It is quite possible that the delivery valve for #3 has stuck open delivering full fuel all the time. Poor compression would not produce large amounts of black smoke.:)
2018 Caterpillar 906M (A53317)
2018 Caterpillar...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
(APPROX.48) UNUSED 2X4X10 PREMIUM GRADE LUMBER (A57192)
(APPROX.48) UNUSED...
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
