Spreading a dirt pile with box blade
   / Spreading a dirt pile with box blade #1
TigerfaninAR
Gold Member
Central Arkansas
Kubota B2320 FEL, MMM
Need a couple dump truck loads of top soil but due to a few trees and an area that may be soft I don't think the dump truck will be able to help me spread as he unloads. So I'll have a couple piles of dirt but I only have a box blade, no FEL. I don't need to spread it far, maybe all of it within a 50X15 ft. area. Can I tackle this with a four ft box or is this like shooting an elephant with a bb gun?
   / Spreading a dirt pile with box blade #2
I can be done, but it will be by pushing or pulling rather than lifting and dumping.
Problem will be more with driving over the dumped dirt, and packing it down. Will need to work the edges of the piles first and plan ahead. Work it before it gets wet down with rain. I'd even throw a tarp over it to keep it dry if rain is threatening. Enjoy the seat time.
   / Spreading a dirt pile with box blade #3
As BT said...also try taking light bites to push/pull not to spin tires.
   / Spreading a dirt pile with box blade #4
If you can back up the pile safely lower your boxblade and skim enough off from the top to fill the box blade as you drive forward from the pile. Raise it just enough when full, so that it does not keep filling. Drag the dirt to the area to fill and raise the box an 1" or whatever works empty the box blade. Then repeat. This also assumes that the arear is somewhat flat.
If you are trying to push fill over a bank drag the boxblade full of dirt to the edge and turn around push it over the side with back edge of the blade.
   / Spreading a dirt pile with box blade #5
if you get in a bind i can run over this weekend and help
i am in central ark also
   / Spreading a dirt pile with box blade #7
Mabe i'm wrong but isn't that one of the things a bb was designed for? :confused:
Have you looked at the video on bb's at everythingattachments.com?
   / Spreading a dirt pile with box blade #8
A FEL would make that job a snap. Knock down the pile with the loader so you can drive over it with the box blade and pull away. I would try to have the truck spread it out as much as possible so you can drive over it. In 50', he should be able to spread it out fairly well for you to use with boxblade. Just don't drive the tractor over the pile and get high centered. If he can't get too close to the area, still have him spread it a little nearby so you can drag it into the desired area. Before he comes back with the next load, have the first load spread out. Then he can drive on top of the previous dirt and dump/spread the 2nd load. Use the boxblade again and spread it out before the next load.
I built up my driveway with fill several years ago. Trucks came about every 10 minutes for 20 loads. Knocked down the piles with FEL and boxblade before the next truck could come. Each truck drove over the previous spread pile. They did a great job of packing my new road as it was being built. The Kubota 3710 got its work out that day and I could just keep up.
   / Spreading a dirt pile with box blade #9
yes that is what i do with the loader
run a big loader a few yrs in a mine and you figure it out!!
   / Spreading a dirt pile with box blade #10
I thought he said in his 1st post he doesn"t have a loader, just a box blade.:confused2:
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A54865)
2018 Chevrolet...
