FEL Bucket Won't Stay Elevated/Level
   / FEL Bucket Won't Stay Elevated/Level #1
EastTnFarmboy
East TN
Kubota L5240 ROPs FEL, JD LX277, Ferris 3100Z
I noticed this evening that my FEL bucket keeps gradually tipping forward as I am driving the tractor.The FEL itself doesn't seem to be falling. I can't see any obvious sign of leaking around the cylinders. I can't see any obvious signs of a hydraulic hose leak. What is the most likely culprit?
I left it in the air with the tractor off to observe it and it does the same thing. Just a gradual tipping forward.
The tractor is less than three years old and has less than 300 hours on it. I just noticed it today and haven't had any trouble with it previously.
I feel like I should know the answer, but I must be overlooking the obvious.
   / FEL Bucket Won't Stay Elevated/Level #2
It could either be a hydraulic cylinder leaking by internally (you wouldn't see an external leak) or it is the control valve.
If you have quick disconnects, you could try swapping the raise/lower ones with the curl/uncurl ones. It you do this, and the bucket still tips forward, it is a cylinder. If the problem changes to the loader itself drifting down, then it is the valve. Just bear in mind that when you change the quick connects, your joystick will be different.
Also, if you determine that the valve is ok, it doesnt mean that both cylinders are bad either. It could be only one leaking by but since they are connected in parallel, it makes it seem as if both are bad.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
