Buzz Saw /Cordwood Saw Restored
   / Buzz Saw /Cordwood Saw Restored #1
SuperA
Shawanagunk NY
FORD 4110 LCG , International 300 Utility, Farmall Super A, Farmall Cub
Anyone else have a Buzz saw / Cordwood Saw Hook up? Like to see & compare hook ups, use, problems etc. I have one i just restored hooked up / Belt Driven By My 1953 Farmall Super A Like to see others Pics & Videos.
Here's the link to my You Tube Channel with the restoration detailed.
YouTube - MrDanoconnor's Channel
   / Buzz Saw /Cordwood Saw Restored #2
Looks good.
What did you do to sharpen the teeth?
   / Buzz Saw /Cordwood Saw Restored #3
Nice work, brings back some childhood memories.:thumbsup:
   / Buzz Saw /Cordwood Saw Restored #4
I had one years ago powered by an A. I think they were most useful when more people had wood kitchen ranges which take small diameter wood. That was a nuisance to hold and cut with a hand-held saw, powered or not. Big stuff was too much labor to hoist to the table - easier to lift a saw.
I remember being impressed the belt didn't slip much, and how much power it took to run the blade. Maybe the angle and set of the teeth wasn't right on mine (I sharpened it with a file several times) but a stick 6" dia. and dry would push against the governor pretty hard.
Fun to use, though not by yourself. Good to see the guard around the blade, mine didn't have that. I recall a fair amount of noise at each cut.
It's good to see the old tools tried out again.
Jim
Looks good.
That was the realy one of the toughest jobs, i used a 1 inch wide Flat and a 3/4 inch wide rat Tail File on each tooth, then I gently used a hand grinder with a soft disc to take any burrs off the metal, took quite a while but that saw Cuts Quick & easy now.
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
