What is your most used implement?
   / What is your most used implement? #23
So far, it has been the chipper, but it will probably be the loader with either pallet forks or bucket once I get the place a little closer to how I want it.
   / What is your most used implement? #24
1 rotary cutter
2 FEL
3 tiller or box blade
I have implements that I have yet to use including boom pole, middle buster, and PHD. They came with the tractor.
   / What is your most used implement? #25
scoop bucket with a 1in peice of rubber bolted to the groud side of the cutting edge on the skidloader. use it to scrape the barnyard and in the pit silo. the rubber keeps from tearing the floor of the silo up and it scrapes the cement holding pen barnyard alleyways and the loafing sheds cleaned nice. its allso nice for scooping grain off the wooden barn floor too.
   / What is your most used implement? #26
The Fel seems to get used the most, either with the bucket or forks.
Rotary cutter (now my flail) is usually mounted on the back year round.
Back hoe, rake, post hole digger, tiller, boompole, box blade, but only as needed.
A PTO chipper seems like a nice addition. I'd have to get a great deal as I'd possibly only use it on branches a few hours a year. I did have one of those standalone types once, but the 3in throat was a pain.
   / What is your most used implement? #27
I believe I fall in the Bush Hog class except for this year, been so dry I've only even mowed the yard 3 or 4 times the whole year here in Maryland.
   / What is your most used implement? #28
In the summer, The discbine to cut hay and the winter the FEL to feed cattle with. Ken Sweet
   / What is your most used implement? #29
What implement do you use the most? I was considering a 3 point chipper. Been burning all my brush for years but it seems to be a waste as could be making mulch and compost for gardens? Don't know if the chipper may be one of most popular implements among all of you. They seem to be an expensive attachment up in the $2500 range.
It depends on the season.
Summer, no competition, 6 ft finish mower. With all of the rain the last two years, I don't have time to use any other implements.
In the spring, road blade: winter ruts and spring washouts keep the tractor busy.
In the fall and winter, the grapple gets the most use. After the underbrush and bugs disappear, it's firewood and woods cleanup time.
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
