What are these holes for? (Part II)
   / What are these holes for? (Part II) #1
picker77
Gold Member
Central Oklahoma
JD 3032E, dual remotes, TnT, tooth bar, grapple
Every time I look at my new JD 3032 I see something else that gets my curiosity up. This time it's "holes" again (photos attached).
1. There are three hefty threaded bosses on the 305 loader's cast iron mounting frame, but ONLY on the right side. What were they put there for? Looks like something pretty stout could be installed there, but I can't imagine what it might be.
2. There are four matching holes, two on each side, drilled through the main lift arm plates. Nothing has ever been in them, factory paint is untouched. Anybody know what these holes are for?
As usual, thanks for the help!
   / What are these holes for? (Part II) #2
2. There are four matching holes, two on each side, drilled through the main lift arm plates. Nothing has ever been in them, factory paint is untouched. Anybody know what were these holes are for?
On the main lift arm plates, might they be for a level rod?
   / What are these holes for? (Part II) #3
You could search in JDParts;)
   / What are these holes for? (Part II) #4
Looks like the three holes might be for the parking stand kit.
(shown in jdparts under P in the alpha index)
   / What are these holes for? (Part II) #5
I wish my Model 70 loader had threaded holes in the mast like yours does. That would be a GREAT way/place to mount a chainsaw holder!
   / What are these holes for? (Part II) #6
G'day not sure on the threaded holes but the other four look like lifting points to me for when the loader is fitted and would prob only be used if you had a crane or overhead gantry as alot of smaller workshops do that fit these thing later in their life
Jon
   / What are these holes for? (Part II) #7
that's where the henway goes..
b
   / What are these holes for? (Part II) #8
not biting are they!
   / What are these holes for? (Part II) #10
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
