Ford manual wont go into reverse
   / Ford manual wont go into reverse #1
Laneman
Looking at one for sale. Appears to be about a 3000 or 4000, ad just says won't go into reverse. Price is right. Any ideas on causes and how hard to fix? Can it be repaired through an access cover or has to be split?
   / Ford manual wont go into reverse #2
It might be something as simple as a clutch adjustment or replacement (especially if it's hard to get into first gear too) or theremight be a broken gear in there.
How hard to fix? Depends on ease of access, does the tractor require splitting, parts availability...
   / Ford manual wont go into reverse #3
not much to go on. is it a manual transmission or the select-o-shift? A manual trans, you can at least pull the top plate and take a peek inside to see whats going on. if its the select-o-shift, those are best left to an expert to repair. Lots of valves, o-rings, and so on in them.
Needing such a repair raises a flag for me. Owner may well be trying to sell because replacing the tractor may be cheaper than the repair itself.
   / Ford manual wont go into reverse #4
To get the best coverage I'd post in the New Holland section.
Also here is another website to look at. Antique Tractors - Yesterday's Tractors : Antique Tractor Headquarters
Charles is correct. Here are basic quesitons to ask.
3 or 4 cylinder and is it manual or SOS.
I've never had an SOS, but like Charles said there are people who run screaming when they see those three letters. Then there are few experts out there who could lead you through diagnosise and repair.
Wedge
How can I tell if it's a select o speed? I'm guessing the shifter would look different than a manual stickshift.
   / Ford manual wont go into reverse #6
we really need to know what it is and what tranny it has.
3000 could have 4spd, 8spd, 10spd sos ( column shifter ).. etc.
4000 should have an 8spd or 10spd.
8spd is twin stick..
post back.
soundguy
   / Ford manual wont go into reverse #7
the select o speed will have a short shift lever under the steering wheel, as opposed to one or two sticks on the top of the transmission.
Its been years since i've run one of the sos transmissions but as i recall the "clutch" really isnt a clutch, but instead interupts the flow of fluid through the trans to give the ability to start, stop and change gears.
Like i said though its been years and i could be mistaken about that.
As i recall also, the sos has a removable filter on the side of the trans. Looks like a large plug with a long skinny screen filter attached.
   / Ford manual wont go into reverse #8
yep.. 'inching' pedal on the SOS is a valve.. not a real clutch.. etc.
soundguy
2025 Wolverine CB-11-750F Hydraulic Concrete Breaker Skid Steer Attachment (A52378)
2025 Wolverine...
UNUSED JMR 40" HYD ROCK GRAPPLE (A54757)
UNUSED JMR 40" HYD...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2013 UTILITY DRY VAN TRAILER (A54607)
2013 UTILITY DRY...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 4x4...
