Question on warming up your tractor
   / Question on warming up your tractor #11
When hot out like it is now (above 80) I start it up, light a smoke and when i'm done, drive off. :) This is also my cool down period after mowing or heavy work. Idle down, have a smoke, and the gauge usually goes from high mids to mid level again.
When it's cooler out and I'm storing it in my heated shed (50-60f) I'll let it warm up a little more since I'll most likely be using it to move snow. Like the previous poster said, let the needle get off the bottom of the temp gauge at least.
   / Question on warming up your tractor #12
A diesel will never get up to it's full operating temperature by either idling or sitting at half throttle as it is in a no-load condition. With the amount of hours you have, the tolerances are no longer what they were when new. The unburned fuel will show as smoke until you build up enough heat (by operating the engine under a load) to close up the gaps (tighten the tolerances) enough to make for a more complete burn of the fuel that has been injected. This is good - diesels like to work, not idle in a no-load state.
It has a mechanical fuel pump, so the amount of fuel being injected is the same when it is cold as it is warm for a given engine speed. The brand new electronic engines (bigger diesels) have many more variables that are taken into account. Charge air temperature, engine temperature, engine load, etc... The amount of fuel and the actual timing of the injector pulse can be varied accordingly.
Short answer - it's perfectly normal. Warm it up like you are, that is good for a number of reasons. Just don't expect a longer warm up time to solve the issue. I wouldn't give it a second thought.
:thumbsup:
   / Question on warming up your tractor #14
deisels do smoke but if you are working it at 2750 rpms you are lugging it and it will smoke and straving your hydro pump of oil to do it right if you read your manual they tell to use around 540 rpms or better ,no matter how fast you go
   / Question on warming up your tractor #15
Has anyone on this board ever actually worn out a diesel engine where it needed a rebuild, i.e new bore and new pistons? I think not. So don't worry about warm up.
   / Question on warming up your tractor #16
I've absolutely worn out diesels to the point of needing a rebuild. It may take thousands of hours, but I've been there, done that - many times, many different makes. I'm not talking a tired engine...I'm talking worn out dead! (piston seizures, crankcase explosions, etc...) Take care of your engine and it will last a very long time.
   / Question on warming up your tractor #17
You are correct. Tractors, trucks all the same...Maintain them and you'll be amazed how long they last...Not talking **** retentive maintenance either...Just what is required and keep your eyes open.
Don't worry about smoke belches once in a while..All normal.
   / Question on warming up your tractor #18
I have seen first hand the difference proper warm up and shut down procedures will have on the life of an engine. Not to say that an engine will not run a long time with abuse but if you want an engine that will last as long as you want the tractor then give it a decent warm-up. Just remember that there are many different alloys and metals in an engine and they all expand at different rates. I have seen pistons seize in the cylinder because the engine was put under heavy load before it had warmed up. Just one example. Most diesels are made to vary close tolerances, much more than most auto engines. Hence the need for a little more care.:thumbsup:
   / Question on warming up your tractor #19
I would like to throw this out there.
I got a new 980 G CAT loader and we got 2 769 CAT dump trucks about the same time. I always warmed mine up winter and summer before operating it and most of the time the trucks were simply started and as soon as they got the air built up off to work they go. Both trucks started giving trouble at around 8,000 hrs and one of them had to have the engine replaced at 10,000 hrs and the other at around 11,000. All three worked in the same location and roughly the same amount of hrs. They had the same engine oil and all had Cat filters at every service. It was almost a daily thing to add at least a gallon of oil to the trucks and it even got to the point that they drivers would just go ahead and take oil with them because they knew it would be low each time the checked it.
My loader on the other hand didn't use any oil between changes and it had 25,000 hrs on it when I got my new one and it is still running today and now has over 30,000 hrs on the original engine. It does burn some oil now but it has been in service for 15 yrs of hard quarry life. I feel like the warm up that I always gave it is the only reason for this long life of basicly trouble free service. I treat my tractors in the same way and have always let them warm up before use. My first Kubota was a mid 70's B 7100 that we bought used. I put this little tractor all amounts of torture for 16 yrs and when I traded it in on a new bota it had just over 6,000 hrs on it.
My opinion in short is this. A good PM program and letting them have a warm up before use will really pay off in the long run.
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
2017 Ram 4500 Bucket Truck (A53472)
2017 Ram 4500...
